Arley Langlo, new streamliner
Started by bvillercr, April 23, 2008, 07:30:45 PM
racergeo
  Why not a more high tech wing that produces more down force with very little drag? That way you don't have the loses of an extra diff and 2 tires yet you still have the down force neccessary to go say 386 like MR Fast Freddy.
jl222
Quote from: racergeo on October 14, 2009, 02:51:28 PM
  Double the contack patch double the traction and I have been advocating variable pitch wings for years. Arley's aero guy is working on a wing type also. High tech wing sounds great getting or developing one is another.
JimL
#17
I was thinking about that traction issue, and wondered if running a flat crank wouldn't be to your advantage?  Honda won several world motorcycle GP championships by stagger firing a V3 2-stroke to get uneven torque input events to the drive wheel.  On the really slippery tracks they had the option of firing all 3 cylinders together!  They also learned that you need to fire like a Harley, if you want to beat a Harley coming off the turns on dirt tracks.
Big traction improvement, there.  I think they already make these cranks/cam setups for Sprint cars....something like 2 cylinders together, then 2 in a row, then a different 2 together, then 2 in a row....kind of like a weird 6 pattern.
Interesting project...fun to read about and thanks!!
JimL
JimL
#18
....or you may need all 6 AND flat crank firing!  This sounds like a pretty big power project!!
JimL
jl222
Yea Jim ... theres a lot to learn about traction in LSR. I mostly raced off road desert but I got real frustrated in a motorcross race trying to pass a Husquvarna in the turns on a sandy course when he would just pull away when I was just spinning my tire. But this was due more to suspension setup than firing order.
  I'm looking foward to the new Hebert streamliner as its fully suspended and the crew chief knows all about spring-wheel rates-suspension points and how to make adjustments.
Automatically pull out a left rear spring rubber at the four?
jl222
Quote from: Stan Back on October 15, 2009, 12:06:57 PM
  No put one in :-D
Ron Gibson
Wouldn't that require a sidecar and a monkey???
Ron
There ain't no f'ing sidecars in Arlies life.
He's as old school as Freddie Dannenfelzer.
They come from the same zip code.
Ron Gibson
I figured someone would have to ride along to add the spring rubber on the go. LOL
Ron
He Don't Use No Stinkin' Rubbers.
I think that's what they call "going bareback", Freud.
robfrey
Cmon guys. Anymore info on that traction curve? Is it really double? I wouldn't think so.
If it's over 70% more, I might be calling Timney tomorrow to order another Extremeliner. I would also think that each one would only have to take half the engine torque. I am concerned about breaking ours as we are over 1500 lbs/ft of torque.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
jl222
Quote from: robfrey on October 18, 2009, 08:31:57 PM
  Whats an extremeliner? There's several books on handling and tire traction curves my favorite is Carroll Smiths book ''Tune To Win''
also Herb Adams ''Chassis Engineering'' The trouble with Lsr is that not a lot of people do it so not as much is learned as in other types of racing. We built our AA blown gas altered 20 years ago and just a handfull have been built since then,same as in A to E. Not much competiion to learn or get pushed foward from.
robfrey
Extremeliner is the Winter's quick change that we use. I like doubling the total contact area but I'm new to this salt stuff and things that I would think would make sense may or may not work.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
