landsendlynda
Good luck MM!!!  Safe journey!  Here's to your Dream    :cheers:   (too bad there aren't any pickle jars to toast with!!   :roll:   Hope your adventure is better than ever!
Lynda
Volunteer roadblock at Land's End! Yes, you need your stinkin badge! I'm your Dream Keeper, I protect your dream on the asphalt so you can chase your dream on the salt!
Dr Goggles
Hey, the car looks great, soak up the trip....have a great time, congratulations.
You did it! :cheers:
Okay - problem I need to solve before tech.
Master switch on back of car is wired to ground (earth).  Now that I finally got the alternator working, neither the ignition switch nor the master switch will kill the engine.
Will putting a switch in the circuit to the exciter be sufficient to overcome this, or will I need to wire a switch to the actual output of the alternator?
Too tired to think, and then, out of the blue, Lord Lucas raises his ugly head!
Safely in Cedar Rapids, drinking a Boddington's with my sister.
Thanks - All of you - The support is incredible. :cheers: :cheers: :cheers:
Harold Bettes
MM -
IF your ignition setup uses an MSD the thing will need a diode so it will not run with the switch off. They have a tech note on their website. :wink:
Hope that helps you with this particular problem. The project has been nice to follow on here. 8-)
Good Luck. :-D
Regards,
HB2 :-)
Zombiezoo
Hey Chris, Joe here, reading with great interest. Hope all is well and good luck. Don't scratch the car!!
Keep us posted when you get a chance.
Quote from: Zombiezoo on September 13, 2010, 06:31:15 AM
Too late.  I'll explain when I get back.  Joe, welcome to the forum!
Quote from: Dr Goggles on September 15, 2010, 03:48:33 PM
where's that Midget?..........................
Kate and I got in late Tuesday after a half-day thrash in Cedar Rapids and a solid day of thrash in Boulder, CO.  Just finishing it as I go.
Alignment, sorting out the electrical and now it's working really well.  Still running a tad hot.  Actually drove the car for the first time around the pits - it's comforting to know that the transmission and rear are working.  Spent today making up a new set of spark plug wires, the driver's meeting, about an hour in line for registration, half-hour tech.  I could have run late afternoon, but decided to get an early start Thursday.  Lines are not long for the 130.
Spent the late afternoon taking it all in with Kate.  This is her vacation, too - can't be too greedy.
#232
Oh, yeah, and it has a new nick-name -
The Pommy Pygmy.
nlancaster
Good luck.
keep us updated.
Well, that's that.
I'm in the lobby of the Montego Bay Casino, drinking bad coffee and am about to head home.
Intermittent ignition problems - starter problems - no heating problems.  Heading home with a 22 mph rookie pass under my belt.  It'll dead rev to 7 grand, sounds sharp and intimidating as hell, but won't pull a pin out of a pin cushion.
No, that's not a typo.  I'll post the slip when I get home.
After the run, I let it sit for a few minutes, and Kate followed me back to the pits.  It was running fine, and she clocked me at 30+ on the return road.  I punched it a few times and it wanted to run, but I wasn't going to get back in line until I knew WTH was wrong.
And that's when the starter started acting up.  I couldn't confirm my adjustments.
Go home, tear down, try it again.
Did receive a lot of compliments - that's encouraging.  The car looks good on the salt, but above that, it clearly presents itself as a genuine race car, and it is, albeit not a very swift one.
Back to plan A.  I've got my crank trigger setup waiting at home, and a second block to start the 970 spec motor.
The  upside - the car itself is essentially done, and I doubt it would have been if not for the imposed deadline of this attempt.  I've got a year to put together a rip-snorting 1 litre, take some time to MAKE SURE IT'S GOING TO RUN, and a better sense of what it's going to take to be ready.
And I suspect time is getting tight on the I-GT record.  It's been sitting unchallenged for 20 years.  There's been talk of an S2000 running 2 cylinders, but with a huge aero and breathing advantage over my old 5 port.  Some talk about letting motorcycle engines into the class, and a fellow Brit-car guy going over the top with an MGB-GT on two cylinders.  If these are my rivals, that's just more fuel for my ambition.
Heading back to Milwaukee with my beautiful bride, a humbling experience behind me, and a clear plan.  I'll keep you posted, and I'll see you next year on the salt.
PS – I've got a really solid 1275 short block for sale – low miles.  PM me.
Lynda -
Slim and Nancy have your pickles!
Chris
landsendlynda
MM
Sorry to hear about the salt gremlins visiting you.  You've done a fantastic job with your build, no you didn't get the speed   :roll:  you were wanting, but you got to chase your dream down the salt and wasn't that the main idea anyway?  Don't be ashamed or embarrassed about the speed, you dreamed of racing on the salt...you did.  One dream reached.  You dreamed of building a car to race on the salt...you did.  Two dreams reached.  No matter how fast you would have gone, in perfect conditions, it wouldn't have been fast enough.... That dream is always increasing.  So, thank you for sharing your dream with us and allowing us to be a part of it.  Those of us who have the salt addiction, but will never do a build and probably will never race down the salt, salute you for the trying and the doing!!
It was a successful build, be proud!!   :cheers:   :cheers:
Lynda
p.s.  Thanks Chris!  I'll be out there tomorrow, sorry to miss you, stay safe!
k.h.
Dang.
Double dang.
Keep us posted.  This has been a great thread.
theazoldcrow
 :-( Chris,,,,, what Lynda said is the gospel!  I've also been watching your build from the beginning and it is with hopes and prayers that this doesn't discourage you in any way!  Keep on keepin on and IT will happen!    Good luck for next year.
hotschue
Chris, I feel your pain........most important....keep at it.....thats what it's all about!
221.559 D/CGC '03
182.144 G/GMS 2019
