Elmo Rodge
Don't overtighten the cover.  :wink: Glad I got that out of the way.  :cheers: Wayno
Podunk
Actually the little trespassers were not squirrels but mice. So I don't have to worry about the soffits . The electrician wiring the new house gave me a tip for dealing with the mice.
Quote from: Podunk on April 15, 2015, 03:32:40 PM
Not only do Hoosiers make better racing wheels, they also make better mouse traps!  :cheers:
fordboy628
Lots of bare 220v conductors?
:-D
WOODY@DDLLC
When wrenching in a HD shop a fellow brought in his big rig in the spring when it wouldn't start or even light the lights. After pulling the shroud off the gas tank there was momma mouse's skeleton with paws and jaws clamped on the hot wire and the little baby skeletons all curled up in the nest so 12VDC with a good ground works just as well!  Organic fuse? :cry: :cheers:
Organic, yes, but how do you maintain a good ground on a Harley?  :roll:
fordboy628
Quote from: Milwaukee Midget on April 16, 2015, 06:23:57 AM
With paint penetrating rodent teeth of course!!   Sheesh!    Haven't you learned anything from this board? ?
WOODY@DDLLC
Chris it wasn't running so the ground was good enough for rodent eradication!  :-D
fordboy628
Uhhh, isn't that what "chicken head" switches are for?
:dhorse:
F/B
Pom Rod report - other than the harness for the headlights and front turn signals, the wiring is pretty much soldered up and in place.  I still have to get the insert for the stripped headbolt, but I'm thinking I should be able to make the final wire cuts this week, test fit the engine and finish wire terminations.  Then it's body work.
Midget update.  I'll be pulling a few components out to donate to the Sprite.  As I'm switching up to EFI, the Holley fuel pump will find new service in the Healey, as will the dual master cylinder.  I'd "T"d the master cylinder outlets for the Midget, but seeing as the racer only needs a single brake circuit, and the Frogeye has been uprated to a disc/drum dual circuit arrangement, it should be a straightforward swap with just minor alterations to both cars.
Heading to Wilmington on the 1st, and I intend to swing up to Michigan and drop off the crank from the K to aid in the creation of the new short stroke piece.
Tman
Very cool on the meeting!
fordboy628
British Nascar
Hope the France family is getting their cut from this Euro-trash . . . . .
https://www.youtube.com/watch?v=w_zK7YyXfFo
jacksoni
Quote from: fordboy628 on April 21, 2015, 11:53:59 AM
British Nascar
YIKES!!
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
WOODY@DDLLC
Should we start a thread on the CG/CP of minis?  :? :?
Or just heist this one!  :evil:
Dr Goggles
British Nascar
the winner there was whoever makes repro panels for Minis
