Bicycle Aerodynamics for those interested.
Started by A2WindTunnel, November 18, 2008, 06:10:19 AM
bvillercr
landsendlynda
Great, I just lost 10,000 more brain cells....I couldn't afford that, ya know!!   :roll:
Volunteer roadblock at Land's End! Yes, you need your stinkin badge! I'm your Dream Keeper, I protect your dream on the asphalt so you can chase your dream on the salt!
interested bystander
Wuz gonna jealously compliment Freud on his generous endowment until I looked closer and saw it was the tailight hanging low under him!
5 mph in pit area (clothed)
Quote from: interested bystander on December 02, 2008, 07:47:31 PM
IB, Freud told me he had to put a hole in the seat to keep from being blown off the bike at speed.... something about the faster he went the better it worked...  :roll:
Any old hole when you're in heat..........
FreuD
saltwheels262
i would like to mount a lsr type fender on conventional mc front end. what are pros and cons between fenders that only provide coverage forward of the fork tubes and those that cover both forward and rearward(within rules)? thanks.
franey
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
I haven't yet done it -- but I'm told over and over that enclosing the front wheel as much as possible is good.  There's air being moved around by the rotating wheel, and since some of that air is being forced in the direction you're traveling (forwards) you've guaranteed yourself some excess drag and turbulence by having that dirty air there.  Cover the wheel as much as the rules will allow.
Then there's the difficulty that was presented by the rules -- stating that no streamlining is allowed in front of the front axle; and that the front fender may cover the top half of the front wheel (I generalize -- the rules are a little more specific).  The difficulty is/was that the front fender covering the wheel is de facto streamlining, but streamlining de jure describes the bodywork, nose piece, etc, and does not include the fender.  There was a whole heck of a lot of discussion on that -- and maybe a rule change, too, to clear up the cornfusion.
Anyway -- cover that front wheel!
saltwheels262
 am looking for a fender from different sources. might have a problem because of size of front end, and homemade isn't an option right now.
red wing front end sliders have inside width of 4.75" ; outside- 8.625" ; tire is a 110/70-17.
hope to come up w/ something.thanks again.
franey
                            - franey  8/2007
sabat
saltwheels262
                            - franey  8/2007
DavidinDurango
Sam Wittingham @ approaching 80+ mph (all human powered)
This is aero!
This bike was SO tiny!  even compared to the other contenders.   Something to think about.
David
DavidinDurango
Mostly Fords with "some stuff"
LSR, because it takes more than one ball to play.
Just imagine that "bike" with a 100 cc engine in it. If it goes 80 with at best 1 1/2 hps think what it would do with 25!! That is AERO!!!
Quote from: Rex Schimmer on December 21, 2008, 11:58:30 AM
Just imagine that "bike" with a 100 cc engine in it. .........Rex
Don't forget all the safety stuff that would also have to fit in there  :cry: .  John and Eric have done about as good as it is going to probably get with the required items.
c ya,
#59
Then there was the guy who came from Europe couple years ago that pedalled just under 75mph lying on his back facing backwards in his 'liner.
The Varna 80 mph plus bicycle record holder, as yrs truly posted a couple years ago on a similiar topic, looks incredibly like one of the NSU record bikes of the '50s. One that even raced around corners!
