Open wheels and aero............
Started by Sumner, February 15, 2009, 05:38:31 PM
interested bystander
A slightly fuzzy series of shots of things rotating with smoke.
5 mph in pit area (clothed)
Bville701
Someone had posted a web-site that actually did a simulation on this subject, but I can't seem to find it. 4-Barrel Mike, can you help me out on this one?
Ryan LeFevers
maguromic
#18
Turning vane on a Ferrari F1 stationary front wheel disc. The picture is from an F1 forum. A friend of mine that works in F1 said the wheel centers are deigned like a turbine wheel to funnel the air through the rim from one side to the other. Officially its been said to help with brake cooling, but I wonder what ells they are trying to do by moving the air to the outside of the rim. Would be curious to know if they are getting some sort of free acceleration from the turbine front wheels.
Graham
Alrighty, I raided a folder at university. Shame I don't have any electronic copies of this stuff but you might want to try looking for work by:
Stapleford and Carr (1970) - multiple wheels, moving ground wind tunnel results vs. stationary ground
Fackrell et al. (1972, 1973 and 1975) - as has already been mentioned. His results are most often returned to by those doing simulations on wheels as a means of validation of the comutational results.
Imaizumi and Yohida (1991) - did experiments on different types of wheels, and specifically on open wheels and partially-enclosed ones (sedan style car).
Oswald and Brone, 1981 as well as Mercker et al. 1991 - studies on enclosed wheels.
Hinson (1999) - experiments on an open wheel conducted for BAR F1, for a range of speeds.
Whitebread (2000) - improved on Hinson's work and looked into the effect of wheel yaw.
Knowles et al. (2002) - made detailed laser doppler annemometry measurements of the wake of an isolated wheel, specifically with regard to the vortex structures.
McManus and Zhang (2006) - detailed computations of the unsteady flowfield around Fackrell's wheel.
Couldn't tell you how useful these papers are to any of you but if you're willing to do some sniffing to track them down they might make for some enlightening reading. The last two probably contain a good summary of what's gone before but a much enhanced understanding of the flow behind and around the wheel just by virtue of up-to-date techniques and standing on the shoulders etc.
Graham Doig
Fluids Laboratory for Interdisciplinary Projects - www.thinkflip.net
Aerospace Engineering Department
California Polytechnic State University
4-barrel Mike
Quote from: Bville701 on February 16, 2009, 09:39:39 PM
It's too early!!!  :-D
Half way down the 1st page and on?? http://www.landracing.com/forum/index.php/topic,5016.0.html
There's more in my first search, but early morning time is limited.  More later perhaps.
Bville701
Thanks Mike!!! Sorry for it being so early and all.    :cheers:
Ryan LeFevers
Dean Los Angeles
The solution is obvious. If the tire is rotating opposite the air flow the turbulence is high.
If the tire is rotating with the air flow the flow is much more laminar.
We just have to make the wheels go the other direction!
Some have had the unfortuate experience of the wheels- and the racecar - going the other way, Dean.
huh, Stan?
I have been there :-o---Mark made a Movie of it---SPINS---its ROUGH on tires-  :-o--hope I don't make the Sequel  :cheers:
Bville701
Kind of hard to spin in your car Sparky?    :cheers:
Ryan LeFevers
Quote from: Bville701 on February 18, 2009, 04:25:29 PM
I guess you haven't seen the video of him at El Mirage a couple years ago.  I didn't know Sparky at the time and was amazed that a car that long could actually spin and not go over.  Those days are now behind him and the car goes real straight now  :-D,
Bville701
I'll have to look for that video. I would've been amazed if I've seen it spin as well.    :-o       :cheers:
Ryan LeFevers
Quote from: Bville701 on February 18, 2009, 06:40:57 PM
I think it was on the SCTA site, but so much there is gone and hopefully the work Dan is doing will keep stuff from going away in the future,
one of the benifits of having "Training wheels" ie a wider track and keeping it "nailed" as it went around---plus a lot luck ----and a guardian angle
