Rear Engine Modified Roadster Build
Started by maguromic, February 23, 2009, 08:33:56 PM
Cajun Kid
Tony,,, wow that mid plate is art work !!!
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
Looks to me like the whole car is going to have a rather large WOW factor! :cheers: :cheers: :cheers:
maguromic
Charles and Pete, thanks for the compliments!!!  :cheers: Its off to the plating shop later in the week for a clear anodize.  Tony
bvillercr
Quote from: Peter Jack on March 16, 2011, 07:35:14 PM
Yes, I would agree.  Your collection of avatars are work of art as well!  Happy Saint Patricks day to you too! :-o
Tman
Quote from: maguromic on March 16, 2011, 08:50:54 PM
You answered my question before I asked it, nice work guys!
maguromic
Yesterday Kevin sent over some pictures of the rear uprights in progress. If they turnout half as nice as his Cadillac heads I know these will be perfect. I cant believe all the lines of code for these. :-o Tony
maguromic
These are some more shots of the reverse side of the uprights being machined.  Hopefully they should be done by the end of the week. Tony
maguromic
Finally the rear uprights are done, they will mate to modified Chevy Malibu hubs.  Tony
38flattie
The number of lines of code always amazes me! I always think that because the part is small, the code should be simple.
That's looking real good, Tony!
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
maguromic
Quote from: 38flattie on April 16, 2011, 05:56:46 PM
Thanks Buddy!   The upright has a little over a 1000 lines of code and the other side is exactly opposite with another 1000 lines of code. Tony
Now I get to enjoy another build diary.
THANX
38flattie
#296
I talked with Sparky today, about a Jimmy 302 for my coupe. This thread was brought up, so I decided to read the whole thing again.
Now my head hurts! Lol!  :-D
There is sooo much good info here, and an amazing build. :cheers:
Can I ask you a couple of questions? Why the cast girdle, instead of a machined one?
Can you expand on the lifter setup, or is that "IP"?
Can you give any details of the head? I just made a deal on a Skinner head.
maguromic
Buddy, The reason I went with the cast aluminum girdle was that the pattern already existed (Doug Robinson was kind to loan it to me) and the sheer size of the part to machine from a billet was too much.  The girdle has three extra mains and three extra cam supports to help with stability (because of our bigger base circle we are using 460 Ford cam bearings).  We also went with Dodge 318 main bearings to uniform everything and moved the thrust bearing to the back.  The big draw back I see is that the two metals will expand at different temperatures throwing the bearing tolerances off.  For this we came up with a starting procedure to get the tolerances we built to.
There's no IP involved with the lifter. Its an idea that and Kay Sissell and Mike Kirby came up with a long time ago and something I expanded on  with the help of Terry Manton to help valve train stability.   Due to the long push rods on the GMC, if your going to run any sort of serious lift the push rods will have odd angles and will be reflected in performance. The small lifter in the head fixes this problem and in our case we are running almost a 1" of lift and needed this to take the angle from the head to the rocker arm (I think I have about three sets left).
The other area you want to look at is the rocker arm attachment. In our spintron runs at high RPM the rocker arms tended to wobble around a bit.  To fix the problem we came with a girdle for the rocker arm, which also acts as the bottom of the valve cover. It attaches each rocker with two bolts.
The head you have is very nice head and would be a great XXO motor.  In our case we are going with a stock head for both XO and XXO, with the XXO running more CI than the 325 allowed for a 12 port.  I don't want to get into specific valve sizes and flow numbers, but I say it can run with the best of the 12 port heads.
The one thing we did from the start of the build was to see how we could optimize everything.  I was very fortunate from the start that a lot of good people was open with help on the GMC, the Ferguson's, Doug Robinson, Armond and Mike Kirby just to name a few.
Now that you are thinking of turning to the dark side, have fun with it and ask away with any questions you have. There is a lot of GMC knowledge on the boards. Tony
38flattie
#298
Thanks Tony!
That's why I was asking. I thought a milled steel girdel might be a more 'natural' fit. Sounds like you have it handled though. :cheers:
So I assume that there is a short pushrod to the lifter in the head, then another from the lifter to the rocker, or does the head' lifter contact the rocker ? What holds the lifter in the head-a milled pocket?
Hmmm, if I had known a stock head could be made to flow as well as a Skinner, I probably would have kept my money in my pocket! :-D
Joe Fontana thinks 1000-1100HP on fuel is realistic. We're gonna see!
38flattie
Quote from: maguromic on May 09, 2009, 09:50:44 PM
Did some work on the parts today and also decided that we will use my my blown GMC 6 first.  It has a F2 reverse rotation Procharger that was taken apart today and sent out to get extrude honed.  The drawing is to scale with the aftercooler and the air box. However I still have to do some CFD work on the air box to see how it will flow.  Tony
Oh yea, I forgot to ask if you could provide any details on your air box?
