Side and Center Stands
Started by landracing, October 25, 2004, 10:05:00 PM
what kind of fool would leave with his chin strap unbuckled......
The same person that you allow to "baby sit" your precious children while you are out partying.
Insanity does jump across generations and state lines. It missed your parents and infected their boys.
JackD
Did we talk about a minumum weight for sidestands ?
Hank
Joe is right.Safety seals for fire extinguishers are designed to break at a pressure that is light enough to do the job,but not be so strong that a smaller,elder person could not break one.
I would be happy to donate all seals needed to secure side stands for the motorcycles.As has been mentioned,the newer bikes are wired to shut off if not in the full upright position while in gear.Removing the side stand is of no benefit to the newer bikes.Perhaps a Mfg. date for factory produced bikes?Sorry guys--I don't get this one.,but that does not mean much.
 <small>[ January 02, 2005, 12:36 PM: Message edited by: Hank ]</small>
JackD
Soooooo, it was that Amo kid that carried the side stand aboard when it was not required to be removed.
A side stand can allow a rider to quickly support the bike even if not on fire. The heat from the engine will make an otherwise ok rider sick while  waiting to get picked up as os required with SCTA. The side stand allows the rider to get off and walk around or even sit down. I found that riding back helped to unwind everything, hovever abuse of the privilage stopped that with SCTA.
Some even do a plug chop and carry the tool with them.
An attached side stand can be done easily and avoids the pat down required if none is allowed to be carried aboard.
The down feature in the wiring is available on many bikes but I don't want one down low around the salt.
"It is funny how some rules are made and applied and some rules are just funny."
JackD
Scott made a funny, or did He just observe a couple ?
He never even said HELLO , so here is some help.
"HELLO"
You see He doesn't always get it right, but actually sometimes leads you to think.
1212FBGS
The Bub rules follow the AMA rules. The AMA is road race and dirt bikes. Side and center stands are no good for road race or dirt bikes. I use one of those triangle shaped drag race stands from Pingle that fit around your foot peg on my 750mpsg. I stick it inside my leathers before a pass. Randy uses one he clips it inside the fairing before a pass. I agree Joe… you need a stand. You just made a pass, it’s 200 degrees in your leathers your pumped up..... ya need to get off your bike and take your helmet off. Some times it takes forever before your chase vehicle gets to ya.
On another note, Joe what did you do to piss this Freud guy off???? He's bagged on ya 6 times for making a rule suggestion! not very nice!
Yours in sport
Kent Riches
1212FBGS
Yours in sport
Kent Riches
joea
my wife told him how well hung my center stand is......
JackD
And Hank has agreed to tie it up for you if it becomes a problem.
You see how easy that was ?
joea
maybe thats why I like the SCTA so much,
I "really" like using my "center stand"
if Judie finds out that it can be tied up,
she would probably rather I run AMA...
Joe  :)
"The water sure is cold."
"Yeah, and deep, too!"
joea
I imagine that yer centerstands are pretty
well secured in Marquette this time of
year,  not many of them hanging down and in the way..........
John Noonan
QuoteOriginally posted by Joe Amo:
If "they" are hangin they are well supported side to side..   :cool:
 <small>[ February 04, 2005, 12:40 AM: Message edited by: John Noonan ]</small>
