Jawa Bonneville Project
Started by AHG, March 20, 2009, 10:08:41 AM
AHG
I am having shocks built in three weeks,
and I am also going to fab up a pair of adjustable length struts.
This way I can run the bike either way to determine what handles best for the salt conditions,
and puts the most power down.
The shocks will be designed with a softer compression, and stiffer rebound,
and built according to the weight used.
The soft compression is easy on the rider (if salt is rough),
and quick/stiff rebound puts the traction back to use faster.
At least that's my theory.
Thanks for the interest :-D :-D :-D
~ I CAN COUNT MY LIFE ON ONE HAND ~
Faith, Family, Friends, Fun & Fast Motorcycles
fredvance
Sounds like you are on the right track.
beerbellykelly
great project-your frame came out mint.
my friend 'east end' lee-[im in london] runs a 500cc JAWA in a replica norton featherbed frame with a czech built  seonara 6 speed box-at SPA-FRANCORCHAMPS-he was clocked at 148mph-in 5th gear-
good luck with your build,i think your choice of single cylinder engine could proove very wise-
P.J.
GOD BLESS THE HUMMIN' CUMMINS
www.jamesandfriend.com
Larry C
You might look into Progressive 440 Shocks. They use an Edelbrock Patened I.A.S. dampening system. (Inertia Active System) it really works great and you can get several different springs as well. The I.A.S. is explained on their web site.
AHG
Hi Larry,
    I'm working with Tom Edison from Works Performance.
As soon as I finish filling out the spec sheet he sent,
they will build me shocks to suit all the bike's and rider's particulars.
Next on the list is the fiberglass, and I think I'm going with the Can-Am Fairing.
However, I have also been mulling over...
Luckyontheducky
I thought you were going to build the world's fastest DUCATI??!!
