Once or twice?
Started by Jonny Hotnuts, March 28, 2009, 08:46:47 AM
akk
Here we go again.... we #920/#928 hold the A,C,D,E GMR records. The A is faster than the AA record and the C is faster than the B record. This summer we are going to run for the B record. We have run the B in years past actually qualified at 275 mph and broke on the back up run. Are we required to make a 175 qualifier?
We intend do a class change to re-set our E record (221.524) with a new driver. There is no way I can find the 175 qualifier timing slip for the run we made on the short course in 2005. Are we required to make a 175 qualifier for this attempt?
holder of AA/GMR A/GMR B/GMR C/GMR D/GMR E/GMR records
You'll get a more reliable answer by asking the question at the SCTA site (www.scta-bni.org) since they're the folks that make the rules.  I know the situation has been batted back and forth here - but I don't know if anyone has come up with a definitive decision.  Let's see what folks say -- and in the meantime, start asking on the SCTA site, too.
RichFox
I would ask when you bring your Contrivance to the inspection or while in pre stage. A new driver in a New (to him/her) car I believe will need to make licensing runs.
mkilger
On the B record you should be ok( with the old driver) ,but with a class change and new Driver you will need to start on the short course work your way up to 175 then you can go on the long course if your new driver does everything  like he or she is told to do.  Is Mr Yale driving this year?
mkilger
after thinking about it now Iam not sure , (what a pain) Iam sure it will be talked about at the driver meeting too
SSS is right on asking SCTA. Also the rule book is very clear on the drivers license and up grades. Pages   12 & 13.
akk
We are not going to worry about it. A quick tune test of the B/GMR on the short course is probably a good idea anyway. The new driver is licensed up in our red 27 car and has done a climb out in the #920 but it will be good for him to make a short coures run to settle him down.
akk
