Experience tell me to rubber mount the carbs.  The front ends of the carbs are in rubber manifolds.  The carbs are supported by a rubber mounted stay.  Nice big fat juicy o-rings are installed in the bell mouth ends to isolate the carbs from them and the plenum chambers.
This is a bell mouth in place on the carb end.
This is the bell mouth in the plenum.  The flow into the bell is less influenced by the nearby plenum wall if it projects.  There is 1/4 inch clearance between the outer edge of the bell and the wall.  This is the minimum I wanted and it dictated the bell size and shape.  The bell would be about a 1/4 inch taller and wider if it was not constrained by the wall.
This engine is not sensitive to runner lengths in relation to power output.  It is very particular about the shape of the inlet ends.  Most of the computer modeling programs and book equations address length much more than they analyze shape.  Dyno testing will be done with both the old and new intake systems.  This trial and error method is the only way I can do it.  The new system will help, hurt, or not change the power curve is my best prediction at this time
The engine design relies on four things and none are used exclusivly.  They are track experience, dyno work, equations and guidance from folks and references, and computer analysis.  All four say the intake tuned length is OK or close to it.  This is where I am very lucky.  The length cannot be increased and have at least 1/4 inch between the bell ends and nearby plenum walls.  The length cannot be shortened and have the big carbs fit behind the engine mount stays.  The intake length is dictated by geometry and it would be a big problem if it was too long or short.
The plenum volume calculations require some precise measurements of port dimensions that cannot be done with the cylinder head on the bike.  The head must be off to make those.  The head needs to be in place for the intake design and construction.  The plan is to design and build the entire intake system with the head on the bike with one exception.  The plenum volume.  That can be increased or decreased after it is calculated. The head does not need to be on the engine to do this.
The air filter flange is shown on the plenum back.  Will the plenum volume also include air filter volume if a big single hole is cut in the back side of the plenum to match the flange?  The inside face of the flange is slightly elliptical with a 2.75 inch minor diameter.  The hole would match that.
Old Scrambler
Assuming sufficient intake-air is available at maximum rpms..............you could effectively double the available plenum-air volume for each intake stroke by cross-connecting the air-chambers :wink:
The air filters arrive on Tuesday.  They will be attached to their flanges.  The filters and flanges will be held on the backs of the plenums.  Ellipses will be scribed on the back of the plenums to show where the intake holes will go.  The holes will not be cut.
The head will be taken off and the intake port volumes, lengths, minimum diameters, and other measurements will be made.  The plenum volumes will be calculated by different methods to determine the optimum size.  This is based on Helmholz resonance principles.
The plenum volume calculation on Page 111 in "Engine Airflow" is rearranged to give plenum volume.  It is VP = Z / [(1 + j) x F] where VP is plenum volume, Z = impedance, j = the square root of -1, and F = frequency
The square root of -1 is an imaginary number.  It was sometime in college in the early eighties when I did some sort of figuring with an imaginary number.  I cannot remember how to do it.  Also, I have no idea of the desired impedance.  Can anyone help me figure this out?
Harold Bettes
Mr. WW and those that like to follow this kind of stuff,  :-D
In the formula you listed that is used in my book, Engine Airflow, there is indeed a wispy old imaginary number which is the sq rt of -1. Z denotes the impedance.
Probably not a "do it this way" application that fits all.
What Engleman was trying to produce there is an acknowledgement of the oscillation of a wave that simulates an Alternating Current wave of electricity. The impedance of a circuit is simply its ratio of resistance to the capacitance oscillation. He had likened the intake system to that of a resistor and a capacitor where a circuit will oscillate as in DC circuits.
One can also look at the intake manifold (including any plenum) as a Helmholtz resonator and the ratio of the inflow resistance to the outflow that can be damped by using a plenum volume (perhaps variable) giving a boost in intake supercharging across a wider range of rpm than the normal approach of a fixed length inlet path. :roll:
Remember that intake oscillations are more pronounced with fewer cylinders than greater. That is another way of stating the pulsations on the intake of a single cylinder are greater than the pulses on a group of cylinders joined by a plenum. Plenum volume typically damps those pulses. :-o
You two stroke guys probably remember the "boost bottle" approaches from years ago. The same kind of application can be done for a 4 stroke. :lol:
Bo, I will send you a PM to perhaps sort out the process which I hope will be of some benefit.
Regards to All,
HB2 :-)
Thanks, Harold.  Any advice is appreciated.  This Helmholz tuning pretty mental for the ol' walrus.  The traditional british parallel twin has pistons that move up and down their bores at the same time and the firing occurs at opposite cycles.  The wave action and pressure and vacuum in a cylinder can be used to enhance the intake performance of its mate.  This engine has a staggered firing order caused by the rod journals being 90 degrees offset.  The wave actions in the intake are nor synchronous and this is why the plenums are being kept separate and it will be tuned like two 500 cc singles.  This was something explained to me years ago by a Harley tuner when I asked him why he always used two Mikuni carbs on separate manifolds for his race motors.  He said "with a staggered firing order one cylinder is at the last tit on the hog" or something like that.
Lemming Motors
Pendine Sands (historic LSR venue) is still used by some groups for speed runs; notably The Straightliners who are primarily motorcyclists but they are very tolerant of other wheeled craft at their events, maybe not Hercules though. :-o
Just a squeeze.
Pages 136 - 138 of this build diary are about Pendine.
Some expert advice in a PM, a phone call a few weeks ago, plus some references suggest the starting point for plenum sizing is 1 to 1.5 times the cylinder displacement at half stroke + port volume + external plenum volume, or the cylinder displacement, or 1.2 times the cylinder displacement.  The plenum volume must exclude the air filter volume if any of these criteria will be met.
There is a filter and a resonance chamber in the air box that Triumph made for this bike.  They are separated by a plate having a round edged slot in it.  This concept will be used on these plenums to isolate the filter.  Does anyone have flow data for different sizes of these orifi in cfm at at 28 inches of water?  The plan is to use the smallest one that will provide decent air flow.
This calculation is for a round edged circular orifice.  The current filter opening is 2.825 inches in diameter with a 6.27 square inch area.  The restrictor orifice will have a 1.437 inch diameter with a 1.621 square inch area.  This is a big decrease and it should help to reduce the intake plenum volume to the needed size.
Old Scrambler
Why build anything smaller than the maximum airbox for high-altitude speed at maximum rpm? Most of the 'books' were written for sea-level air.
The design is for sea level.  That is plenty difficult to do.  Hopefully it will work on the salt flats.  A fellow forum member is kind enough to give me some expert help.  Google "The acoustics of racing engine intake systems."  Links will appear to the paper by Harrison and Dunkley.  The paper can be read from some links, like the one from Cranfield in the UK.  That paper is what I am trying to figure out now.
The predominant wave action at high rpm is the harmonic resonance within the intake runners.  Helmholz resonance effects from the plenii are minor in comparison.  The reverse is true at lower rpm.  The drivability might be increased by helmholz tuning.  Not much performance increase is expected at high rpm.
The air filter spigots are 2.75 inches inside diameter.  They will be welded onto the backs of the plenii.  Holes 2.385 inches diameter will be cut out of the plenii backs within the spigots.  Plenty of air will flow through these holes from the filters to the plenii.  The helmholz resonance frequency will be relatively low for this large volume.  A dyno run will be made with this arrangement.
The walrus valves will be installed in these holes.  They have only 1.45 inches inside diameter.  They isolate the plenii from the filters.  The helmholz resonance frequencies are expected to be higher within these smaller volumes.  Another dyno rum will be made with this setup.
The elliptically shaped walrus valve side facing the filter is very efficient at passing air.  The other side facing the plenum is sharp edged.  It is very inefficient, flow wise.  The valve effect comes from it being much easier to get air into the plenum from the filter than to blow it back out the other way.  Hopefully this will help to reduce power loss from reversion at lower RPM.
