Engine displacement tolerance?
Started by Rex Schimmer, June 29, 2009, 05:42:26 PM
slopoke
#15
John Noonan
Quote from: slopoke on July 14, 2009, 04:10:00 PM
Quote from: NathanStewart on July 13, 2009, 01:30:59 PM
Sleeve it down or offset grind the crank.
Or do both...
Not for bikes.....
My crank has been offset ground (destroked over 14mm) then welded and I have done it before and also debored the stock bore so I know it can be done.
Also have made offset pistons as well.. :cheers:
saltwheels262
[/quote]
how does that work?  like stroker pistons?
franey
bub is  about 6 wks.; maybe you can still make it.
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
