New I/G Streamliner Build
Started by Jerry O, July 01, 2009, 06:21:19 PM
Jerry O
bvillercr is correct. The wheel wells will be made into the body. I did this so when the body is off the chassis, it will be much easier to service the car.............Jerry
Jerry O
A few more photos of the car.  Forward view of the gauge cluster. The lever on the left is the shifter and the parachute is on the right. I can shift the trans and deploy the chute without taking my hands off the steering wheel.
It may be hard to see but I am using two master cylinders. I have two brake rotors and calipers on the rear that are independent. In the event one fails, I still have brakes.
Another view of driver area.
Here are a couple shots of the roll cage. Gives you a idea as how the driver is positioned
theazoldcrow
 :cheers: Beautiful!!!!  Looking forward to seeing you on the salt.    Crow
#18
Tried that with your firesuit on?
bvillercr
Sad to say but true.  I hope you have, things can get tighter than you think with a suit on.   :-D :-D
oneliterlandspeed
Jerry,
You have done a fine job on your build, First Class. I do have a few things I would like to share with you if your are interested about our world of small streamliners.
terry@ecs-systems.com
Fast Wishes...
Terry
The need for speed...My favorite quote.."You must be fast because I was haul'n a.s.s. when I passed you!"
Luck has little to do with land speed records. Good luck comes from thousands of hours of painstaking details others may not consider important.
3 I/GS records and 1 I/FS record
Dynoroom
Jerry, I was looking over the pictures again and it looks like you might have aluminum heim joints in the suspension. if you look at rule 3.T in the 2009 SCTA rule book they (aluminum) are not allowed. Just a heads up. Great look piece for sure though.
Jerry O
Sparky.... I have sat in the car with the fire suit on, it is tight but thats the way I like it. In the event of a crash, I don't want to move around in the car. As for the aluminum rod ends, those will be changed to 4130 ends. You guys are doing just what I need you to do. Look the car over and give me feed back. Its a long trip from NC to Bonneville only to have the car fail tech. Thanks again everyone.
JerryO
oz
A really nice piece of engineering Quality job!
floydjer
Very nice build. Good luck. J.B.
is there another inside metal liner panel that comes back to your shoulders that is not installed for your side shot? are there frame tubes or substancial steel plate underneath your body length to keep you from going out the bottom during a pencil roll ? If some one were to grab your knee and yank up and back how much comes above the frame rail?
Terry:
Well, what a pleasant surprise to see you on this Forum.  We haven't heard much from you -- or about you -- in quite a while.  It's good to know you're still following the sport.
Nancy still remembers the time you had her sit in your 'liner.  Still remembers the claustrophobic feelings it gave her. . .
Will you be at the Salt this year?  If so -- make sure you look us up for a quick hello -- at least.
oneliterlandspeed
Hey Slim,
Very nice to see you noticed...
I'm still alive and well. After the fire in 2002 I have gotten married, built a new shop, built a new home, built a new facility for my business and oh ya rebuilt the streamliner from the ground up to run blown fuel, YES!! we will be back on the salt again in August and September, Don had open heart surgery three weeks ago, he is ok but recovery will take a few months so he will not be on the salt this year.
Jerry think you can't wait to be on the salt for the first time... after 7 years it hurts...man I just can't wait...
I remember very well the day Nancy got in the car, the look was panic and pleasure at the same time...hmmm I think that would sum up every run on the salt LOL. I have converted my web site to a blog site, take a look at    http://oneliterlandspeed.blogspot.com/
Fast wishes everybody,
Terry
Jerry,
VERY Very NICE!! Your design and fab skills are pretty appearant.
You know that if you come to B'ville, and I sure hope you do!, you are going against a Costello record which is probably the "softest" if you can call 229 mph soft,of all the records that that car has,  but I would love to see your car.
Jerry O
Rex......... The Costello record will be the one I go for. Like you said, the I/G record may be the softest one to go for. Still a big challenge for me. I have talked to Jack a few times and he has given me some good advice.
Sparky....... Yes there is other panels in the car. As for tubes under the driver area, I have four tubes going from left rail to right rail spaced equally under the floor. There is also a tube that runs down the centerline of the car for the full length of the drivers area. It is set up with a double floor. The one I sit on that is attached to the top of the frame rails, and the belly pan. The car would have to come completely apart for me to come out of it.  If you pull my knees up and back, no part comes above the top rails. I may have a photo showing the bars, I will post it if I do.........Thanks...Jerry
