D/STR Roadster...fuel, brake, wiring routing questions...
Started by slepe67, August 27, 2009, 12:01:15 PM
Cajun Kid
It's hard to beat the SFI approved  Lakewood... it runs between $309.09 and $359.95 depending on where you get it and part #..
The Lakewood SFI bellhousing comes with the "block plate" and all bolts  too..
Just an option.
Good luck with the build.
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
slepe67
yeah, I am going to take that route.  I like my legs!
1932 FORD 5 WINDOW COUPE, ORIGNAL
302 SBF, 4 Speed Top Loader
MONTANA BORN & RAISED, STATIONED IN FL
4-barrel Mike
RichFox
I have. It's not easy to buy one for a Packard engine, or even a Pinto. But I would never make one if I could adapt one from the store.
Rick Byrnes
Rich is right.  My Pinto block didn't have a ready made housing, so I reconstructed a 5.0L Ford Lakewood.
BEWARE though,  Cutting and welding the hydroformed structure causes some really weird distortions.  Flatness and concentricity become a big issue that requires additional machining.
It is worth it though....
Rick
1 fast evo 2
Quote from: thundersalt on August 28, 2009, 08:11:15 AM
I know a lot of guys run Holley regs with no problems and will probably be OK for you application. If you have ever taken apart a Holley pump or reg you can see how small the passages are (I could probably urinate more flow after 3 bud lights). I have been using a Magnafuel pump and regulator and happy with the results. :cheers:
I've been thinking about trying there (magnafuel) big 2500 hp fuel injection pump but I'm wondering about durability.
Which pump are you using and do you have any problems with it ?
E.C.T.A. 200 MPH club
221.4 mph at Maxton sept. 08
thundersalt
http://www.magnafuel.com/index.html
I have used the Quikstar 300 for 3 years with no problems. I like that the magnafuel pumps are a constant flow/pressure system with a bypass unlike Holley which is a demand pump that shuts on and off when needed. Even their fittings are larger I.D. than other AN fittings.
916 REMR
El Mirage 200 MPH Club
stratman59
I know alot the fast drag cars around here are running Mangafuel pumps with no
problems. Looks like a neat setup, but you have to run a return line to the fuel cell.
Robbie
