Kawasaki 1000cc A/G - Recycled Racer™II for El Mirage
Started by Dakzila, October 06, 2009, 12:55:00 PM
Dakzila
Quote from: Rex Schimmer on January 20, 2010, 09:11:38 AM
Buzz,
I am not a "bike guy" but that is a great looking bike. I usually make the first Elmo meet so probably see you there.
Thanks Rex.  I'm a car guy too, Mopar's, early hemi stuff.  Stop by and introduce yourself in May...
Buzz
oz
Dakzila
Quote from: oz on January 20, 2010, 10:22:41 AM
Lookin better and better SWEET!
Thanks oz.....can't wait to see if she runs.....
Buzz
Dakzila
Well I'm another step closer to being ready for the May meet at El Mirage.  The bike is finished, the new turbo engine runs, the tranny shifts and all seems right with the world!
I just need to do some tuning on the high side of the S&S Super B carb (that should be fun---NOT), change the class numbers to 1350 cc A/BF and then take her out for the maiden voyage (around the block).
I'm anticipating some issues with tuning the S&S as I've never worked on, or ran, an S&S carb and I've never build or ran a turbo engine, so this is all new to me.  I'm glad I've got some extra time to fiddle with this setup before the event in May (I just hope I don't hurt the engine while I'm trying to get it setup)........
A couple of shots of the finished bike......
Looking forward to seeing everyone in May....
Buzz
bak189
The bike looks great......except for that aircleaner......we ran almost the same cleaner including the elbow
.....would not pass enough air at full bore......We used a KZ Kawa with the same Turbo set-up as yours, at 10lbs boost........get another air-cleaner set-up........................................................................
Question authority.....always
It looks great.  Its nice to see it coming together.
John Noonan
1212FBGS
Dakzila
Quote from: bak189 on March 22, 2010, 04:24:05 PM
bak189,
I really appreciate your input and candor. The air cleaner has been a source of problems since I decided to run the turbo.  I felt the cleaner I came up with was too small but my plan (and don't shoot me) is to run the bike in May and make an initial pass or two and see how the bike runs.  If I feel the bike would run better, with better intake air flow I'll make a couple of passes without the air cleaner (gulp). If I get my 1000cc normally aspirated engine completed by mid-June This turbo engine is coming out of the bike and going on the shelf so I'm not too worried about hurting it.
I f I decide to run the turbo for more than one meet then I'll see if I can come up with a better (read bigger) air cleaner.
Thanks again for the advice.
Buzz
Dakzila
Quote from: John Noonan on March 22, 2010, 05:54:40 PM
Looks good and a bit "toasty"
I'll need to pay close attention to my left leg John  :|.  I'm going back and forth on whether or to wrap the exhaust.  There a little more clearance than appears in the photos but I know the exhaust is going to get hot.....fast!
Buzz
Dakzila
Quote from: 1212FBGS on March 22, 2010, 07:52:05 PM
itz to pretty to get dirty Buzz......
kent
Thanks Kent, I appricate that coming from you.
I wasn't able to to use the pipes I got from you, the turbo hit the rear frame down tube.  If you need the pipes (for parts) for your project just let me know and I'll let you have them back. I appricate you taking the trouble to get them to me in the first place.
Buzz
Dakzila
Well it looks like it time for "Plan B"...... :cry:
Only 19 days until El Mirage and I buggered up the turbo last Saturday.  Not sure whether it's just a seal or the shaft.  Lot's of smoke coming out the exhaust and a small puddle of oil in the exhaust housing.
I'm having no luck finding anyone to repair the turbo in time for the May meet so guess I'll throw on a different cylinder and pistons, find some carbs, and run in the 1000cc A/G class.
It could be worst...it could have happened at the meet and ruined my whole weekend.......
Hope to see everyone in a couple of weeks......
Buzz
Sorry to read about the last minute big problem.  There are always one or two, it seems.  Good luck at El Mirage.
Dakzila
Thanks Wobbly,
I was only going to run the turbo for the May Meet anyway so this is maybe a blessing in disguise. Now I can work on getting the bike to up to speed in the class were I have a chance at the Record.
Thanks Care,
Buzz
PS: Been reading your build diary and looks like the triumph is coming along nicely....
summer heat
I know this is an old post, but very curious how the runs went, and updates on your class record chase ???
Have taken my stock kz900 to Bonneville and looking at doing something new with her, so this post was very interesting.
Thanks
