1350cc Pushrod bike
Started by JimL, January 23, 2010, 08:04:02 PM
JimL
Oiling system complete tonight.  Pumps from the front engine into the remote filter, and then to the main galleys, trans, and gauge.  I had to "double deep" the front sump in order to get even depth between the engines.
....more to do
Beairsto Racing
Getting closer! :cheers:
I'm looking forward to seeing and hearing your bike.
2 Club since '02
Sponsored by: Turple Bros.,
JimL
Thanks for the nice words and encouragement.  Some days it's a struggle, some days ok.
I'm fitting the fiberglass, now, and had to move the footpegs (again) and will have to move the oil filter (???where???).  The belly pan is a tough work out, due to the low frame rails because some fool just HAD to put two engines where one should be.  There will be some holes in the right side, to get the exhaust out of course.
I couldn't use the TZ750 throttle because nobody wants to tackle the cable (bringing it back to you Kent).  Barnett can solve the cable, so onward we go, and it'll be easier to fit up than 4 individual runs.
At least the rear brake works well, and there's plenty of room for the shift linkage.  I need 3 batteries on the left side (too heavy on the right, and a big electric water pump (Dedenbear), two fans (SPAL), two starters, two ignitions).  Maybe ballast as well, but it may have to be in my left boot! :lol:
The good news.....it's a sub-200 record and an obviously sub-200 bike....I can get tires!!
JimL
Sidebar to the project....a pic of the tiiny little "shop cat" that has adopted our back door.  Looks like this is as big as she gets, and tomorrow night I've got to trap her and get her to the vets and take care of some trouble.
Nice to have someone drop in to talk to you while you're working.....even if it's only to say, "FEED ME, FEED ME!"
oz
Looking good jim wish i was coming this year!
Carefull with the little critter it might know Judo.
ttfn oz
1212FBGS
lookin good buddy... i got those intake rubbers for ya and also the jets.... remember i have that solder pot and can make you the cables or ya can just borrow it and make em yourself...
kent
JimL
Exhaust pipes coming along.....belly pan will need a little work, and a little bulge in the fairing.  Tuning for 10-11000 RPM, here.
Jim,
Do I detect a slight megaphone on the end of your headers?? That thing should really sound great at 10,000!!! Progress is looking good and thanks for keeping us posted.
Jim
Very intriguing!  What will it sound like?  Like a 4-cylinder?  Or are the motors phased to "echo" each other?  Or what?  I'm excted to see and hear it.
Stan
JimL
We are ALL wondering what it might sound like (hope it's not just BANG...CRUNCH).  The firing order is:
Forward cylinder fires,
180 degrees later the third cylinder fires,
then 100 degrees after that, the #2 cylinder fires,
and then 180 degrees after that, the #4 cylinder fires.
weird.... :?
John Noonan
Jim I am sure it will sound like this when revving it up.....Vroooom  Vrooom..Vrooom...Vrooom   :cheers: :cheers:
oz
I aint no expert but why the,what seems to me an odd firing sequence?
Oz
JimL
Cylinders are at at 80 degrees angle.....only engine I've ever seen like that.  The stroke is so short, they don't seem to vibrate much.  Expect it'll be worse with the higher compression and almost no flywheels.
desperately trying to get this thing fired up by the end of the month....
JimL
#88
Had to move the #2 megaphone outboard about 3/4", in order to get the tip flush to the fairing.  The rest of the fairing mounts came together well, so tomorrow I'll move on to the ground stand.  Need that done so I can fit the belly pan to the exhaust pipes.  The bike will be about 4" higher than the position shown, once it's sitting on the tires (ordered BT003s....though this thing isn't likely to get close to 200, unless I can figure out how to bore and stroke these engines someday).
Happy fathers' day.
JimL
JimL
A little more progress....
Up on wheels/tires, belly pan reworked to fit the pipes, intake manifolds are on (but need to modify the rear one).  Battery tray has to be redone (I'm going to put the batteries more left, to balance the bike and get easier access.  It will also make room for the water pump where I really wanted it.
