Incredible Software Deal
Started by saltfever, March 03, 2010, 12:56:15 PM
saltfever
It looks like we made it! As of Sunday evening 1003 bundles were sold. Have we all just increased our competition? :-D :-D
rockstar
Just a quickie.
Does the bonneville software work fo M/C and if so how accurate is it?
Dave
Remember Murphy's 6th law,if all goes well,then you have missed something out.
Team Sparrow Racing UK
saltfever
I haven't had the time to seriously use it yet. However, it deals with all the standard stuff like atmosphere parameters, engine HP curve, Cd and frontal area, and gear ratios (trans and final drive). It will not use a tire less than 6" in width. I don't know why there is a tire width limitation.The big deal for a bike would be knowing your Cd. There also might be a weight limit. Meaning there may be a lower limit for the program to calculate and a bike may not meet it. Physics is physics . . . quantifying the variables leads to accurate results. But in the case of a bike some of the inputs might be outside the calculating range of the program.
jacksoni
Quote from: rockstar on March 19, 2010, 01:30:31 PM
Just a quickie.
Dave
Generally agree with Saltfever. I just opened  up my copy of BV pro. It will take tire width of 3-21". (remember this program is an outgrowth of a drag race program), Tire diameter 1-60",frontal area 1-100sqft, Cd up to 2.0, weight 750-19500 (including driver of course),wheelbase 24-300...Looks like they were calculating for go carts too.  anyway, if you can get decent Cd and frontal area, it will give numbers.  has been pretty accurate for my firebird, but thats different story
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
saltfever
#19
Thanks for that update, Jeff. I had just downloaded it and tried it for the first time. For some reason it blew up when I input my 5" wide Bonneville tire. I'm sure it was user error. :cry: Based on what you say it looks like a motorcycle could easily fit into the limits and it would be a useful program. To get CdA, Rockstar could do a coast-down test and get very accurate results since it includes area as well as Cd in the result. Cost-down tests are extremely accurate if done correctly (but it is not easy to be accurate). I think the archives may have something on a coast-down or Google it. Allowing for relative wind and the tire-to-ground contact are necessary for a good test result.
EDIT:  I just checked my program (ver 3.2.2) and the tire width in inches is 6.5 - 22. That eliminates just about every LSR Goodyear. My download was 2 days ago and I'm assuming it is the latest version. What version do you have Jeff?
rockstar
Thanks for the info guys,will do more research!.
Dave
jacksoni
Am running it on two different computers and not sure if identical versions.  But it is 3.2.2, 2003 on my one at home where I am now. It shows 3.5-21.5 width accepted.  Not sure the discrepancy. However as I mentioned before about the drag origin, don't think means much for LSR. And just now running a simulation entering a 5" tire and a 20" tire it made 0.6mph difference( out of 230). I wouldn't worry about it, enter the smallest it will take.
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
saltfever
Yeah, good point, Jeff. . . it makes very little difference. Tire slip (i.e., salt conditions at the time of the run) is probably the greatest unpredictable variable and will cause a greater deviation from the calculated results.
My program displays the tire widths you indicated when I press the tire worksheet button. However, when I enter a small dimension it defaults to no less than 6.5" width.
jacksoni
Just playing with  it again, the allowed tire width changes with tire DIAMETER! What were you using there?
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
saltfever
Interesting!  I was using a 87.9" roll-out (i.e., the 28" diameter Goodyear). When I get time I may get back to the author and ask about a few quirks. If so, I'll post results. Right now I'm busy with "tax time".  :cry:
