Banger Belly Tank
Started by Fordrat31, March 16, 2010, 05:28:50 AM
hitz
I believe Joe Timney was one of the founders of ECTA and being a chassis builder (Delaware Chassis Works) would see the need to angle that front loop. The SCTA would no doubt be conscience of that but it's possible that one of the old roadster boy's (bless their souls) has a car with a upright front bar and is sort of grandfathered in. No big deal unless it causes some injury.
CTRon
you said:" go figure".
interested bystander
This topic should probly be combined with the other.
The 110 ECTA angle in my senile mind seems to translate to 20 degrees from vertical (straight up and down) like the SFI specs.
5 mph in pit area (clothed)
Fordrat31
Well it sure has been a long time since I have made an update here so I figured I should get on that. I had to put the car aside for about a year untill I was able to get settled in at my new shop. Once I finally got back to it I decided that I needed to tackle the roll cage and get that finished up. I completly re-designed the hoops, shortned its stance, and laid back the front hoop to 122 degrees to comply with the rule book.
Everyone I have contacted so far about the cage has approved.
Speed, you have to make it your friend, then convince it to volunteer on you team
Fordrat31
One more pic.
RidgeRunner
Good to see you are able to get back on the build again.  Shop looks good, plenty of elbow room!
Life stuff has had us in a bit of build hibernation as well, should be back at it soon.  Will send you an email when we are.
kiwi belly tank
Definitely looks a lot better down there & it'll be a bunch slipperier too.
Your wall is looking a little Burt-ish there mate!
Fordrat31
I am really glad I was forced to go back and re-do the cage, I think it has a much better design now. Hahaha yea I might have took a few ideas from Burt, I needed somthing to hang up there!
Dr Goggles
cage looks way better....
When you're building these things there is no right ...but there are heaps of wrongs.
If there was a right most of "us" wouldn't be interested in them.
Bunch of door-slammer guys scratching their heads right now. :wink:
kiwi belly tank
 You're right Goggs, Ya see a few people that can take a tank & ugly the crap out of it. Sitting up on a kitchen chair surrounded by a pile of monkey bars is a sure way to get there.
Building a tank is a whole different experience, if ya haven't gone there ya just can't know. Everything else gets built & then ya hang a body on it. A tank is more like building a house in a cave. When I built mine, I had a new respect for those who had gone before me.
Maybe we should put a "Tank" register together, seeing that we are such a screwed up.... I mean different bunch!
Fordrat31
Well I had a good amount of time to work on the car over the winter and I took full advantage of it. First on my list was to change the rear end mounting, my original design just wasn't up to par. The new design triangulates the rear and make it much stronger. With the rear mounted in its new home I finished up my final mounting brackets for the transmission. After 3 different transmission choices I finally decided on a three speed side shift, using a Clings adapter.
I also got the chance to fit the top half of the tank. When it was all said and done I ended up with 9.5 inches of cage sticking out the top of the tank. This should work perfect for making a fairing, and keeping it as low as possible. Once the tops half of the tank was mounted I decided to build a water/fuel tank. The water and fuel tanks will be two separate tanks but placed next to each other to make it look like one tank. I started with a insulation foam mold then build the final tank for 1/8" aluminum sheet. If my calculations are correct the water tank should hold 14 gallons and the fuel tank 3. This will put approx. 125lbs directly over the rear end.
Fordrat31
I am trying to post a few pictures but for some reason it is being extremely difficult.
Fordrat31
More
Fordrat31
Few more.
grumm441
Hey
That's a good looking tank
Nice work
Dr Goggles
Quote from: kiwi belly tank on October 15, 2011, 08:43:00 AM
you're a genius Sid.
Hey Drat,nice tank .....aaaaaaand we do have a tanks only place....I have been a little negligent, but it's there...
http://www.dlra.org.au/forum/viewforum.php?f=19&sid=5a9a3d6d239bed2a50d8bdcb8565519a
you'll need to register for the DLRA forum to get access but it is for the people who get tanks and tank stuff. Like being a musician, then being a country musician,then having to explain to other country musicians what you're into....well us bellytank guys are into um..... well yeah we're into lakesters but really we're into BELLYTANKS :roll: :roll: :roll: :roll: :roll: :roll:
