Cb160 Turbo Project Pictures
Started by Chaulkdust, May 09, 2010, 06:08:29 PM
Chaulkdust
I am running a small FACET fuel pump good for 10-11psi. I needed the fuel pump since the boost pressure actually slows/stops the flow of gas to the carbs. So I have a boost adjusted 1:1 Mallory regulator that increases the fuel pressure as the boost rises. I set the initial fuel pressure at 2 psi or so and the regulator does the rest.
Right now I'm running the stock point setup, but I plan on putting in a pertronix electronic ignition setup before I go to BUB.
I'm using a RHB31 Turbo (the smallest I could find).
Ron Pavlak
Florida
racer x
It was great to see you and you bike at Maxton . I hope Bonneville will be cooler.Best of luck at BUB .I hope you will be back at Maxton in September.
Chaulkdust
Thanks Eric, yep I'll be back in Sept & Oct for more attempts (assuming the bike still running after BUB :roll:). Great meeting you and all the other folks, seems like we were in line together a lot at the starting line in the 96 degree heat!
Ron Pavlak
Florida
