today at elmo
Started by racefanwfo, June 13, 2010, 01:36:28 PM
We set our record last month during Bonneville tune-up time.  Let's see 84 MPH in 1.3 miles equals 323 at the 5.
New fuel injection either makes A WHOLE LOT more mid-range -- or the course was shittey -- or both.
Going slow makes for better pictures, too.
I've been told -- "Me doth think he protests too much."
And paraphrasing one of my favorite book titles by Vincent Bugliosi --"and the Salt Shall Tell".
dw230
One side like Eyre's.
They will be running four cars at Speedweek, pretty ambitious.
And so far, pretty successful.
jdincau
I just realized, that means we need a chute to run the lakes now. Oh well it's the drivers inheritance i'm spending.
jimmy six
Good Luck Jim on reattaining the record with a true engine vs. 1/2 of another one. I really never cared when this was done in special construction vehicles but didn't like it when I saw them filter down to the other classes in the late 70's. It will be tough for your Chevrolet 4 to compete against 1/2 of a V-8.
Jimmy Stevens has done the best and holds the record at Bonneville running 170. His Fontana block had a Ford Yates head and it took him a few years. Good Luck..JD
Dynoroom
Wow JD! I never knew.......    :-o
I seem to remember that the Novi took 2 set of Offy cylinders (well almost as Goosens did design them) & bolt them to a common crankcase to make a v-8.
Then there were those guys who defanged 1 cylinder to drop a class.
Also seem to me that the GMC 12 port is an unfair advantage with it's inlet port tilted up 45 degrees.   :-D
This is only to start some lively debate as the forum is a bit slow lately.   :cheers:
dw230
Mike,
Whose GMC 12 port head is that? The Wayne GMC 12 port had straight ports, the Chevy head had the angled ports.
Dynoroom
You're right Dan (of course) it was the Chevy head that has the angled inlet.
Now, was that different than the factory Chevy 6 head?   :-D
willieworld
I have a couple of pics that were taken at El Mirage. I thought that I would post them here and hope that the subjects in the pics will see them.
A couple of the pics are for Kent(I owe you one). The others are for first timers and over the ponders. Hope that you enjoy them.
Sheri Buchta
willie-dpombatmir-buchta
Modern day wild bunch :-D
desotoman
Quote from: jimmy six on June 15, 2010, 09:11:24 PM
Good Luck..JD
JD,
????????????? Sorry but I am confused. If you can put a late model V-8 head on a 4 cyllinder block, what is the difference? What am I missing? Wouldn't they put out the same HP?
jimmy six
The GMC head is a Howard. It was the only one with 45 degree intakes. It used the same injector as the Wayne. It is now the Arias and Harris runs one on his Camaro.
Tom, I know they are just air pumps but for years 1/2 motors seem to have an advantage. With todays knowledge and the advent of more SOHC and DOHC "F" engine classes are making a come back using all cylinders. Barry Kaplan could sure make a 1/2 engine run and I believe Freddy does pretty good too.
jdincau
Duggan also made a slant intake head for a Chevy 6 in Australia.
RichFox
The Howard/Arias 12 port head appears to be a clone of the Wayne GMC head except for the intake ports. I was told that Howard used the patterns for the Wayne and modified them for his version. Don't know how true that is. The Duggan head for the late model 292 type Chevy I believe is now the Sissel/Duggan and not a cross flow head. I had a Howard head on my 32 Ford/GNC and then sold it to the Salt Circus roadster.
SlyOneJr
I'm with Tom on that, I know that Udo and Jack are running real good with the Pontiac "Iron Duke", and that my Dad's engine (191 cid "Iron Duke" with a splayed valve small block head on it) hit 394 hp on the dyno, don't understand where the performance difference could be, unless instead of running the "pancake" crank like the four cylinder does (180 degrees), they are running a 90 degree crank like the V8's run. Is that where the difference is? The power pulses?
Jeff
New Guy building a L/Gas Lakester
Ninja 250 powered Lakester for ECTA meets
