drag radials
Started by revolutionary, July 06, 2010, 10:46:15 AM
Fheckro
Saltfever,
amen brother !
Fred
9479 Monza C/CGC
Current record Holder @ 180.000
flyingkiwi97
I very rarely take part in these discussions but for those of you interested this was my official reply ;
Hi Daryl,
We are very wary of tires we are not familiar with. And these tires are also a lot wider than the majority of cars use.
For tires that are not originally designed for sustained high speed use, we have a supervised limited speed program we will put you through.
This will consist of supervised runs at , 175mph for the first (depending upon license), 185-190 for the second, 200 for the third, then 210, and so on.
The tires will be checked after each run for heat, damage, wear, or any other unusual effects they might suffer.
Handling problems or irregularities are also a concern with wide tires, this is another reason you will be supervised.
Be advised that the race surface on the salt is very different to Maxton.
Please contact Joe Timney for advice on the surface differences.
Please make yourself known to myself or Lee Kennedy upon your arrival in the tech area.
Regards,
Steve Davies.
Chief Car Inspector SCTA/BNI.
flyingkiwi97
Thats my 2 cents worth.
If anyone needs to reach me, my email is in the rule book.
1212FBGS
Kiwi
on those aircraft tires they were talkin about in this thread.... havent we been limiting them to 250mph....
kent
bvillercr
Not all wide tires have handling issues, just cars that have the wrong set up. :mrgreen:
flyingkiwi97
Hi Kent,
All aircraft tires (or any tires seeking approval) go through the entire tech committee process, they have the final say.
1212FBGS
pretty sure they have a 250 cap.... Right Stainless?
kent
revolutionary
Kiwi, just wanted to say thanks for all the help you guys gave and to let you know that I could not have been happier with how Mike went the extra mile (so to speak) to make sure he was on the return road at the end of every pass checking out the tire wear and temps. I had backup tires available (which I did end up using) but hopefully I can bring these back next year and we can do some more testing with them. In the mean time, I'm going to try to get in touch with whoever I can at MT to see if there is any further testing they can provide that will help out.
Breaking Wind #9614
  ECTA Record AA/BGALT 214.8
jl222
Quote from: revolutionary on August 30, 2010, 09:31:47 AM
  How did the two tires compare and what were the temps?
revolutionary
Both tires and rims absolutely cool to the touch and the drag radials handled much better.
Breaking Wind #9614
bvillercr
#70
Quote from: revolutionary on August 30, 2010, 08:55:32 PM
white car, my mistake. :-D
saltfever
What air pressure did you run in the drag tire?
jimmy six
Salt...I asked that on the first page and never saw a reply..............
saltfever
Quote from: jimmy six on August 31, 2010, 02:29:22 PM
That is an important question! That is why I asked it again.  :wink:
836dstr
#74
OK, not quite on the topic, but relevant. At Speedweed we had a fairly low speed spin. I told the driver "go fast at the other end". Anyway at reinspection the Goodyear "Drag" Frontrunners were deemed unacceptable to continue racing. The tires are roughly 10 years old and had been exhibiting a circular seperation in the sidewall about 1&3/4" above the rim. After the spin you could feel the sepertion and peal the sidewall back about 1/4' toward the rim.
Anyway, I bought a set of LSR Goodyears from Gary Hart. With the cost I want to get the maximum life out of them. Looking at Jim Dincau's link I had some questions:
1. Can you get nitrogen at a welding supply store?
2. I have seen posts about storing LSR tires without any "Air" in them. Does this go for nitrogen filled tires?
3. I have also seen posts about storing the tires in black plastic bags in cool places?
Can you comment on these and any other methods for extending the life of LSR tires?
