History question- When did the Pushrod Class for Motorcycles start?
Started by dr j, August 02, 2010, 10:05:10 AM
k.h.
Well, Harley supplied the Buell engines as OEM, per Buell's relationship with the Motor Company that said they had to use them.  And Buells established a number of records with their modified OEM engines.  A quick look at the records for pushrod 1650, I believe the MPS-PF set in 2004 is the same engine/chassis run in APS-PF in 2005 after the change S&S cases were dropped from M.  So, a record is a record, and might not have been attained if the rule hadn't changed things.  Some historians can hash it all out when we're taking dirt naps.
mike mendoza
1212FBGS
ummmm..... if i remember correctly didn't Harley own Buell...... ok yes im a smart azz
kr
k.h.
That's it.  I re-read the debacle of '06 on the Pushrod M/C stuff.  Now, there's some pushrod history.
http://www.landracing.com/forum/index.php?topic=928.0
