new 2011 rule changes
Started by KEVIN, October 20, 2010, 06:43:33 PM
dw230
Score one point for Pete.
"no less than stock length or width", not real hard to understand.
Real life experience here. When we raced the Alfa, pre-Cook, we used Bob Noice's PSI blown Rodeck at one El Mirage meet. The size of the blower put all that mass higher than the roll cage., outside the body. This is kinda like using an OEM sized radiator in Gas Coupe. BTW, won the season championship at that event.
Our mantra at that event was, frontal area does not scare us - we'll horsepower thru it.
LittleLiner
Quote from: saltfever on December 17, 2010, 11:52:07 PM
Since CdA is usually what is important in LSR I would suspect area is the deciding factor. The GC rules require stock sheet metal and no blanking off holes. Are you saying you can fit either geometry within stock configuration?
What I am saying is that I cannot fit a radiator in my car that is as wide as the stock OEM Radiator mounted in the OEM location.  Part of that space is now occupied by part of the engine.  So even with the clarification, amendment, etc the rule still pushes my setup out of GC and into Altered (after I cover up the headlights).
All in all the new wording of the CG radiator rule seems like a good rule clarification and I can live with that.
javajoe79
 Maybe this was already mentioned. I read it but it was a long thread.....
  The radiator rule is what I am talking about. Even with a smaller radiator, unless you block the unused area, all that air is still going into the engine bay and not providing any sort of aero benefit. If they are just trying to prevent any aero advantage then why not have a general rule outlawing any method of obviously blocking airflow?
615-210-1605
javajoe79
Quote from: wjesel on December 05, 2010, 06:25:23 AM
I've just returned from the Indy trade show and there was a very nice display of Polycarbonate windows and windshields. The company is Shields Windscreens and their website is racingshields.com They have worked on some landspeed projects in the past. Seemed to be very nice quality.
Shields makes great stuff. I have used their products in the past in several road race cars. They can also make any windshield for a reasonable price if they don't already have a mold. You can send them your windshield or pay like $75 for them to source one locally then add that to the price based on thickness, supershield, tint, antifog etc.... the prices are all on their site.
615-210-1605
dw230
I have just sent the following to all effected web sites, look for this to be posted on scat-bni.org and landracing.com.
Rewrites for pending rules issues:
3.A.3 Driver's Helmet SupportLateral Movement: The seat, roll cage structure or suitable restraint system, such as a restraint net, swing away bar or similar such device, shall provide restriction to lateral head movement of less than 2 in. per side inclusive of structure deflection, and at a minimum extend to the forward most portion of the helmet see Section 3.B.1.
3.U   WINDOWS AND WINDSHIELDS:
All non-stock windows and windshields shall be made of shatter-resistant plastic, such as polycarbonate (Lexan), and shall provide 120 degrees of adequate vision forward. On all open body cars a windshield is recommended, but shall not restrict driver entrance or exit. In all classes where a headrest fairing is permitted, the windshield may sweep around the driver's head and connect to the fairing on either side (see 3.E Driver's Compartment rule concerning sharp edges).
All windshield wiper blades and arms shall be removed. On front and rear windows, retaining tabs or straps are required over 175 MPH.
Vehicles with T-Tops or moon roof panels shall have the panels retained with tabs or straps.
All vehicles over 250 MPH shall replace all non-laminated safety glass windows with polycarbonate material. All other glass, such as headlights, must be covered with SAFETY film.
Beginning January 1, 2012 all vehicles in classes where the record exceeds 200 MPH must have all non-laminated safety glass windows replaced with polycarbonate material.
Beginning January 1, 2012 all vehicles with "frameless" side windows, regardless of speed, must have all non-laminated windows constructed of polycarbonate material.Additional bracing must be installed to prevent window blowout or collapse.
Bob Drury
  Dan, thanks a million for running those two rules back through the committee.  It just proves again that LSR is not a "us versus them" deal, and that our voices can be heard.
  Thank God and Slim (in no particular order) for allowing us to use this site for more than just shmoozing.........  Bob
                                                :cheers: :cheers: :cheers: :cheers: :cheers:
Bob Drury
Mayor---thanks for your efforts  :cheers:  :cheers:  :cheers:
Bville701
Hey DW, Thanks for ALL that you do, but can you please ellaborate on this a little bit? Does this mean that we do not have to have a HNR of 38.1 SFI type for 2011?
Thanks again!  :cheers:
Ryan LeFevers
Dynoroom
Ryan, the above is in addition to the HNR system 38.1.
The change is in the way you retain the helmet in a laterial (side to side) movement. The SCTA has given options here compaired to how the rule was first conveyed.
Bville701
Ryan LeFevers
YAY!  I'll still be able to barely get into and out of my car! :-D
Dan, thank you for shepherding our concerns on these issues.
Chris Conrad
Buickguy3
 Thanks, Dan, and have a Happy New Year. See 'Ya in August.  :cheers: :cheers:
Doug
                   [America]
Avanti Kid
Dan, do we still need to have safety film on both sides of windows that are not liminated glass?? or is that only for glass headlight lenses on cars going over 250mph?? Or has that requirement for safety film been deleted for this years racing (2011)??? sure hope so.   I wasn't sure with the most recent write up for 3.U in rule book, thanks Dave
Original owner of 1963 Avanti; Age 84
2006 Bonneville 200 MPH Club Member
Canyon Country, CA
215.6 mph 289 CI Studebaker engine
dw230
If your car was legal for 2010 it is legal for 2011.
The rule still states that safety film is needed for glass lenses such as headlights.
Ron Gibson
  I understand what the rules say, "BUT" (you know how that goes) wouldn't it be safer to have formed sheet metal with decals instead of glass in the headlight sockets? I put chip guard on my roadster lights but if they broke it could still let the rest of the sealed beam headlight glass fall out of the bucket on the track.
  I was going to use wheeled aluminum and decals until you pointed out "headlights must be used".
I,m not talking about streamlining, just replacing the glass sealed beams with metal and decals.
Thanks
Ron Gibson
