T5 advice : WC or not to be... WC?
Started by Jeff Brock, October 21, 2010, 12:20:01 PM
BudJ63
I don't know if this will help or not, but I found it usefull trying to identify some parts I had scrounged up. Along with the head and block casting numbers, there is a GM tranny gear ratio chart.
http://www.thedirtforum.com/castings.htm#tranny
38flattie
#16
Quote from: Jeff Brock on October 22, 2010, 10:08:05 PM
Buddy, I'll look into the 833. It just so happens that in a strange dark corner of the studio... there are 2 or 3  833's. I did not know they were stronger than a Muncie.
I am leaning towards more gears, closer ratios with 1:1 top, though.
I'm currious about Richards Tremec 6 and G- force 4 experience.
I think I need to compile the shift ratio data from the transmissions I blew.
The T-10 w.r. gear spreads and the Muncie c.r. gear spreads and find a stronger trans that splits the difference in a 4 speed or speads it more even in a 5 or 6 speed.
The gearing is different than a Chevy. Here is a 'cheat' sheet for you.BTW, you didn't answer- you running BVGCC? Why not punch that out one more CI, and come up tp XXO?
And if you have an extra close ratio 883, I'm looking for one........
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
Richard 2
Jeff,
We never used the 6 spd with the 3.00 as there was no need to because the 800 hp the turbo 4 cyl esslinger (ford Pinto)  makes couldn't pull 5th (.80) over 8000 rpms and 6th (.62) was a disaster and we needed to reduce our rotating mass (because of flywheel issues) so we went with a tilton 5" 4 disc, clutch, flywheel and the 101A G-force trans (formerly 101 Tex trans) with a Long inline shifter (witch is really a nice shifter plus the 101a is clutchless). The 101a has an endless range of gear ratios available. We used 2.32, 1.56, 1.20, 1.0 witch worked very well, of course now we have to push the car off the starting line. So what I learned the hardway was that overdrives rob to much HP. Here is a mph calculater off of the currie site that is really handy. http://www.currieenterprises.com/cestore/calculators/mphCalculator.htm
Rick
4 cylinder Esslinger
Could of had a V8
Jeff Brock
Quote from: 38flattie on October 23, 2010, 08:34:40 AM
Thanks, Ill look into my "dark corner of Mopar" and see if I can id the 833's We may need to run #'s I'm not sure what they came out of.
If I keep dinkin around  with this engine I'll have to step up to XXO
BROCK ART SPEED
Jeff Brock
Thanks guys ... I listening to all and compiling.
Long shifter is a "for sure"
I am heading to Ventura Ca. in a couple days to pick up the 1950 Buick Sedanette {fastback} that will be the next LSR approach.
Wait till you see what I have brewing for this car!
Anybody need anything hauled out to Ca.  let me know.I have a mostly empty flatbed and car trailer headed west.
BROCK ART SPEED
38flattie
#20
Jeff, are you going to continue to run the 'Bombshell', or is it going to be retired?
Are you going to stay with the WWII nose theme for a name?
Coral Queen?
Hobo Queen?
Lady Eve?
Miss Fortune?
Smooth Sue?
Temptation?
Wonderous Wanda?
My favorite- Uninvited.
Like Bombshell Betty, all of the above adorned actual WWII bombers.
saltcatracing
We look forward to seeing whatever you come up with as your last (1st) effort was so cool!
