1973 camaro AA/CGC
Started by BALS aSALT, November 01, 2010, 05:04:15 PM
Leadfoot
Why not consider Production or Altered glass ? then add a quickchange for Gas Coupe class?
BALS aSALT
Quote from: Leadfoot on November 05, 2010, 10:30:57 AM
trying to get into CBGC eventually, but since i got such a good deal on this bullet, i figure i'll cut my teeth in CGC, then change over.
it is better to live one day as a lion, than it is to live one thousand days as a lamb. or maybe it is better to burn out than fade away.
dw230
Tall block is not a defined engine swap.
BALS aSALT
Quote from: dw230 on November 05, 2010, 07:37:01 PM
DAMMIT!!!!!!!!!!!!!!!!!!!!!!!! well i am at the mercy of the committee board. i should get my letter from them on Mon. or tues. i keep reading that rule book and it's still a pain to understand.
RichFox
I know about building your own car and all, but did you see Dick's Firebird for sale here? I think it sounds like a pretty good deal. Save some work building your own completly.
robfrey
You might want to think about a quick change (extremeliner or similar). That would make you legal and there sort of nice to work with. I was very impressed with ours. Looking forward to seeing those build pics! That car has always been one of my favorites.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Cajun Kid
Quote from: robfrey on November 05, 2010, 10:47:57 PM
Rob,  does your QC  use 35 spline axles ?  what ring and pinion?  spool or locker ?
Thanks
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
robfrey
Quote from: Cajun Kid on November 06, 2010, 07:58:38 AM
Thanks
Charles
The lakester we built (rebuilt) for for Dennis L. used the 3.08 r&p but out liner will use the 2.00 r&p and both have 35 spline axles. The 3.08 will get down to 1.84 ratio and a spool is readily available for it. Not so for the 2.00. I don't plan on using a spool in the liner. Got everything from Joe Timney.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
BALS aSALT
here's a picture of the bullet.
BALS aSALT
here's one of the camaro.
jl222
#40
Quote from: BALS aSALT on November 06, 2010, 08:17:26 PM
 I was in a Ferrari store at Wynn's casino in Las Vegas wednesday and they had a formula I 10 cyl engine on display,
[3 litre 800 hp]with nice carbon fiber inlets similar to those gold ones, as the throttle linkage was there I couldn't resist moving it and those inlets moved up and down about 2'' :-o
BALS aSALT
mine don't move up and down, but the engine does move forward when the butterflies are twisted open. odd :? :? :? :-D :-D :-D
BALS aSALT
ok, how about since this bullet is considered a pontiac and pntiac headed engines didn't come in a camaro. now do i have an engine swap? :? :? :?
38flattie
#43
It's a Chevy block, or a Pontiac? If it's a Pontiac block, as verified by casting numbers, you should be ok, depending on if it's newer or older. The old Pontiac blocks were different than Chevies.The fact that you said it was a "tall Block", indictes it's a Chevy. Pontiac didn't make a tall block, did they?
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
BALS aSALT
