engine location
Started by BALS aSALT, January 21, 2011, 06:03:04 PM
38flattie
Quote from: Stan Back on January 24, 2011, 12:22:39 PM
You could always put a spark plug in the water pump -- but I'd bet Dan would figure that out.
Stan
You think?
'cuz that would sure make things easy for me! :evil:
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
fastman614
We had a problem understanding this rule 35 years ago and it was not until somebody..... if I recall correctly, it was JD Tone.... pointed out that IT IS NOT IN RELATION TO THE ORIGINAL POSITION OF THE ENGINE.... THE ORIGINAL POSITION OF THE ENGINE IS NOT RELEVANT.... it is only from the criteria included in the book.... if you have a 100" wheelbase car, the setback is a maximum of 2" BEHIND the front axle centerline.... being that we were allowed a 2" body stretch (similar to NHRA pro stock rules and which put us into Altered-where 25% setback was allowed)... it all went out the window for us anyway... but boy do I remember the snail mail exchange!!!!! and you would think that, after all these years, (and NHRA having similar rules too) that the definition of setback would have been made clearer....
Dynoroom
For Altered class my rule book says 2% body stretch (not 2") in front of the fire wall.
It also says engine set back is maximum of 25% of the wheel base per Section 4.AA
Page 42, 4.AA of the 2010 rule book states........
The feature of a car is represented by the formula D/WB where D is the distance measured from the front spindle transverse centerline to the front-most spark plug hole or centerline of the front most cylinder on compression ignition engines and WB is wheelbase.
fastman614
Quote from: Dynoroom on February 05, 2011, 09:21:13 PM
Yes that is exactly what it says.... the 2" was because the car was 100" wheelbase.... you gotta give me some slack here .... these discussions were over 30 years ago!
As you correctly point out in the word for word rendition of the setback rule, the criteria for its determination is there.... only thing is ....many of us assumed that you arrived at a number from that formula and then you SET YOUR ENGINE BACK THAT MANY INCHES FROM THE ORIGINAL STOCK LOCATION.....
Ron Gibson
IIRC, JD that told me that if you change from a bbc to a sbc using the same mounts, the set back to the spark plug will be different. Legal with a bb will give too much with a sb.
Ron
dw230
"many of us assumed that you arrived at a number from that formula and then you SET YOUR ENGINE BACK THAT MANY INCHES FROM THE ORIGINAL STOCK LOCATION....."
In that case many of you made the wrong assumtion.
fastman614
Yes, Dan, you are absolutely correct....
