"Ground Effects" Tunnels
Started by Dynoroom, May 27, 2011, 08:49:35 AM
akk
Yes rolling resistance exists and at speed is small compared to aero drag.
My earlier comments about lead are not meant to belittle underbody design! My point is that there are better ways to get down force at Bonneville. Properly shaping the underbody can result in significant drag reduction!!!!! Don't waste drag reduction trying to get down force....below 350 mph...
Akk
holder of AA/GMR A/GMR B/GMR C/GMR D/GMR E/GMR records
I could not agree more with AKK's comments regarding using aerodynamics for down force on a Bonneville car. All methods of aero down force have a lift/drag ratio, even under body tunnels and both the down force and the drag increase as the square of the speed, which means the horse power to over come the drag increases at the cube of the speed, so even what may appear to be a small amount of drag can become considerably larger with only a small increase in speed. We have discussed before the possibility of controlling a wing angle such that it produces a set amount of down force at any speed which would also control the drag but I have not seen anyone try it.
Bville701
Quote from: akk on May 30, 2011, 03:31:05 PM
The fact that you saylift to drag ratio should cause you to stop and think....
We have a very long straight away...any drag will slow you down!!!!!!!!!!
computer simulation shows that until you are running 350 mph...lead is better every time!!!
LEAD = "DRAGLESS DOWN FORCE"
Akk
Akk, how much do your cars weigh?
Ryan LeFevers
akk
The 23T 920/928 with lead rack full...2928 lbs. rear and 1358 lbs. front....total weight 4286 lbs.
with lead rack empty 2182 lbs. rear and 1350 lbs. front... total 3532 lbs....(note the car is built with a lot of steel and has 800 lbs. of lead built into the floor)
One year running B/GMR on the long track with good salt coefficient of friction=0.6, with a  full lead rack was 3 mph slower than with empty lead rack!
We have learned the hard way that too light in the rear causes spins! Our discipline is to add weight if the tires spin in second gear...if we cannot spin the tires in first gear we remove weight....
The logic is ....second gear is about 1.5 to 1ratio... thus in high gear with 1 to 1 ratio we have a 50% traction safety factor!!!!!!
The 23T has no up or down aerodynamic force, it is neutral..ie zero lift to drag ratio... no induced drag
Akk
Bville701
Thanks for the info Akk!  :cheers:
Your cars are VERY impressive! Have either one been in the wind tunnel? If so what kind of drag are you seeing, if any? Thanks again for the info, and I agree that weight is better than a wing at Bonneville but what do you do when there aren't any more places to put weight? Do you think that ground effects are the way to go? Wing? Fin?
Ryan LeFevers
George Fields
If it spins the tires, add weight, if it doesn't add nitro!
Bville701
Quote from: George Fields on June 08, 2011, 03:15:15 PM
LOL!    :cheers:
Ryan LeFevers
Bob Drury
  In the word's of the late, great Randy "Macho Man" Savage: Ooooooooooooooooooh yeah!
  Tip the can............. then tip a Beer.............   :cheers:
Bob Drury
akk
I am trying to pull this thread back to aerodynamics....
Carroll Smith has written some good books about building race cars...he is a straight shooter as he admits that his earlier books were not right on ground effects...however he has some good points...the nose of the car should have the same ground clearance as the body at the rear...the middle can be closer and form a venturi in the middle...the high velocity can create down force with minimal drag...our car has never been in a wind tunnel...
Akk
WOODY@DDLLC
More than half the HP is inertial - you still have to accelerate the lead!  :-o You don't have to accelerate down force!   :-)
You have to push hard against both but there is a balance or sweet spot in all things!  :cheers:
Still easier to find than the G-spot though!  :-D
When you are entering the 5th mile and you are looking for that last 200 rpm on the tach, the last 4 or 5 mph, it ain't inertia and acceleration that you are fighting it's aero drag.
akk
Put a wing on it and you will never get a chance to find that last few mph's! You will have downforce and be running 20 mph slower......
Akk
Akk,
why no rake  :?
with a round shape on the bottom how would you determine the ground clearance
akk
In the middle ...where the oil pan and transmission hang down...ground clearance is about 2.5 inches....nose about 8 1/2 inches...back bottom of turtle deck about 11 inches...the small rake is to prevent the flat part of the bottom from ever being higher in the front than in the back...suspension travel +_ 1 inch ie.9.5 front 10 rear...
The goal was to have the whole car neutral...the suspension allows ride height/spring rate verification of up or down forces....the car is aero neutral...but you can see torque lift of the nose and rear squat...about 1/4 inch...
Akk
Question rephrase   Have you ever read how much clearance a cylinder needs agl  :?
