Driver Compartment - Fire System Nozzle Placement
Started by BoredAndStroked, August 02, 2011, 12:24:53 PM
BoredAndStroked
Hey Gang:   Setting up the last aspects of the FlatCad car and need to know where you guys put the driver fire system nozzle . . .  as I've done it with road-race cars, but never built a BVille car.
We have a 10 lb system - will have one 180 degree driver nozzle and two over the headers in engine compartment.   I was going to install ours next to the driver (on the right side lower cage or floor) . . . and have it set to spray to the middle of the body.   Obviously you can bend the aluminum tube and change the direction, was just wondering from practical experience where you guys put them, and where you direct them (at the driver).    On our road-race cars we have about 4" of flexible aluminum tubing past the mount point - so we can bend/set the angle . . . the nozzle head is NOT fastened down.
Thanks again . . . much appreciate the help you're giving a BVille newbie!
B&S
Member of FlatCad Racing Team - 2011 - 2025
Goal:  Have fun, make friends, be safe - learn as much as possible, contribute when I can and hopefully see this beast of a Flathead Cadillac go over 200 mph!
DallasV
Ours is near the firewall between the drivers legs aiming right at the "boys" if you know what I mean. Sounds like your close to that.
BoredAndStroked
On my road-race mustang, it is to the right of the driver - kind of above the shifter location on the driveshaft tunnel - sticks up about 4 inches and sprays mid-body.   The does not mean this approach is "correct" of will pass tech at BVille.
Cajun Kid
You MAY have a problem with using only one BIG fire bottle for both engine and drivers compartment.
I am not 100% sure, but just tossing this out as an FYI...
You need one bottle for engine fire and one for drivers compartment (activated with separate controls)  The reason for this is the discharge rate..
also imagine this you are at the 3 mile mark and boom the engine blows and fire flares up.. you pull your system and all the agent discharges to the engine and all over you and the interior... then before you get stopped it flares up again !!!..
Now with 2 systems,, same thing,, but you pull the engine fire bottle, puts out fire while you are getting stopped,,, if the fire flares up again.... not you can pull the interior fire bottles if needed...
Just my thoughts,,,,  more nozzels on one big bottle shortens the discharge rate and most likely the fire is not in both areas at the same time,, if it is pull the other system and get out,,
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
BoredAndStroked
Quote from: Cajun Kid on August 02, 2011, 01:26:06 PM
Charles
I believe we are fine up to 200 mph?  If we are over 200 MPH, then I believe we'd need 2 bottles . . .
Joe Timney
What type of system do you have...gas or aqueous foam??? It makes a difference!
Joe Timney
Retired President of ECTA
www.delawarechassisworks.com
BoredAndStroked
Quote from: Joe Timney on August 02, 2011, 01:29:32 PM
DJ Safety - what they call 'cold fire foam' . . .
RichFox
Mine is the same as Dallas. Are you going to be in C/CGALT? Running on  245 record? Don't you have to build for the record? I have a 5 and a 10. First one is split between me and the engine. Second one is "Forget the car, I want out."
Dr Goggles
Quote from: RichFox on August 02, 2011, 05:15:40 PM
Good point.Get a dedicated one for the driver , just a small one. Then you know you'll pass tech. When you're upside down, and you can't get out it'd be nice to have something to bide the time because chances are you won't be parked next to the fire truck.
we have two tens.
1./ "I think the car is on fire"( harder to tell in a mid engined car with no side mirrors)
2./ I AM on fire
Joe Timney
There are three company's that do aqueous foam. If foam, you MUST NOT have nozzles aimed at driver or windshield. One of the things I have learned from a " Fire Engineer" is that you should not just add nozzles...a properly engineered system that meets the SFI Spec of how much product is dispensed in the required time relies on a specific number of nozzles and do not use other manufactures parts as they have different flow rates...it just YOUR life that depends on it. Ask your manufacturer only.
As for as one big tank or two small ones, the guy I rep for suggests that we fire all the systems at once to cover the job before it gets big.
Joe Timney
Amen to that, Dr. And with a mid or rear-engine car, you are the last to know that you're on fire. I burned down a Porsche 911 that way.  :oops:
38flattie
#11
Haha! Thanks for all the answers guys!
Dale, Here's my answer, after talking with everyone, including DJ Safety, when I bought the system.
A bottle with 10 lbs agent, with 1 nozzle on the driver, and two on the engine, is good up to 200 mph.The system was engineered this way, we didn't change it.
That is all we need for XXO/BVGCC!
The fact that we are switching, and running the SBC won't effect us, because we won't run in a class. All we are trying to do is make sure the car will pass tech for /BVGCC. In addition, we want to shake the car down, and get licenses.
So, after all is said and done, we'll be running 'time only' this trip. I've been we should be able to do this, and have a 'speed limit' imposed upon us.
Now, if I'm wrong on something, please speak up guys!
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
interested bystander
Charles ,
Thanx for forwarding your "THREE MILE EXPERIENCE"
5 mph in pit area (clothed)
old chevy truck
" I believe we are fine up to 200 mph?  If we are over 200 MPH, then I believe we'd need 2 bottles . . . "
I have not seen what class you plan on running. I hope you know you need too build to the record in that class. You wrote about intercoolers and dry sump. That sound like a serious build. So check the record and build to that record. Otherwise, you may be limited to time only (actually speed) and it may be a lot lower restricted speed than you hoped for. Its a long drive from Ohio to be limited to 150mph.
