Speed Demon Unofficial Timing
Started by Dean Los Angeles, August 25, 2011, 06:21:55 PM
Dean Los Angeles
Pulled from the 2011 video.
Who needs a big gas tank when you are only going to run a lousy minute and 18 seconds?
MileSpeedElapsed Time
000:12 pull away from push truck 50 mph
1/4103    20:20 second gear
1/2153    27
3/4191    32:33 third gear
1    226    36
1 1/4254    40
1 1/2275    43
1 3/4295    46:46 4th gear
2    317    49
2 1/4332    52
2 1/2349    55
2 3/4353    57
3    371    1:001:01 5th gear
3 1/4381    1:02
3 1/2387    1:04
3 3/4396    1:07
4    409    1:09
4 1/4413    1:11
4 1/2414    1:13
4 3/4421    1:15
5    426    1:181:18 chute out
Schruiber
I never knew a chute can be deployed at 426mph? Is it a special high speed chute of sorts?  It's a question from someone who never used a chute (on a car).
T-2011 - Granite Falls HS UrbanAutos Diesel - 31.16668MPH over the measured mile  at WoS 2011.
Dean Los Angeles
This is the video that I used to pull the information.
http://www.youtube.com/watch?v=TxbYuoTQdFw&feature=player_embedded
The first chute to be deployed is a small drouge chute.
The large chute is deployed at 300 mph!
"Who needs a big gas tank when you are only going to run a lousy minute and 18 seconds?"
Well, Dave Davidson told us at the 200 MPH Club banquet that the 911 car's speed and distance limitations are limited by the amount of fuel the gas tank can carry.  If I remember correctly -- he said the tank holds 27 gallons of fuel - and that it runs dry at just past the 3.  Let's do the math:  3 miles and 27 gallons is 9 gallons/mile, and 27 gallons times the price of nitro -- what it is, $30/gallon? - $810.  Now I know the car doesn't run 100%, but ethanol ain't cheap, so discount a few bucks and we still end up with $500 +/- for a single run.
The 911 car DOES need a bigger fuel tank - and it runs less than 1 minute 18 seconds!
