storing l s r tires
Started by mstrdinan, August 31, 2011, 06:53:45 PM
mstrdinan
we are going to store the goodyears until 2013
anybody have any ideas on this ??   (air press.  etc. )
        thanks
Bob Drury
  IF they are mounted, drop air pressure to 25-30 psi, use a rubber protectant such as formula 303 aerospace spray, or meguires rubber protectant, and keep them covered (even flourescent light's will deteriorate rubber Don't use armorall or any cheap sh-t.)       Bob
Bob Drury
k.h.
Marvin Rifchen, the M in M&H and who used to make LSR tires, said store them in the dark and coat them with carnuba wax.
jimmy six
I place them in large black trash bags after coating. I use a vacuum cleaner to suck out all the air I can and tape up the bags and keep then in a unlit shed...Good Luck
Vinsky
Any truth that the date may determine whether can use the tire regardless of the condition? I think BUB is implimenting this protocol.
Tman
Mine are stored in hefty bags in a cool dark place. As for the wax..............what do you use to clean them up before use? Or don't you?
Moxnix
I don't know.  Need someone older than me to ask.
Dean Los Angeles
I presume you're asking about car tires, but here's a comment that's applicable to bikes - and your question.  SCTA rules state that "street" tires must be stamped by the manufacturer with the date (month & year) of manufacture.  Race-only tires do not have that restriction.  I don't know about Bub's/AMA rules, as usual.
Vinsky
I refered to BUB 'rules' since Mad Max at one point had been told he couldn't run the Firestones from Arfon's / Teague
projects due to the age / date. Later said he could run this year.
