Parts ID: Early Olds? Pontiac?
Started by 4-barrel Mike, January 05, 2012, 09:00:01 AM
4-barrel Mike
Old abandoned project (not mine).  Attempt was made to use one side on a Model A Ford block.
What's it fit?  Manufacturer?
Base(s) may have been trimmed.
desotoman
#1
Mike,
Could be a Cad also. Look on the sides of the injectors, if they have not been machined there will be casting data if they are Hilborn's. There will aslo be a small number that has been stamped into the injector, usually between the center two ports, like 131 etc.
4-barrel Mike
No stamped or cast numbers anywhere  :?
Outer ports ~10 3/4" center-to-center
Inner ports ~7 13/16" center-to-center
Distance between inner ports ~6 1/2"
MIke
