Motorcycle Ground Clearance
Started by peterdallan, January 19, 2012, 03:46:10 AM
peterdallan
Hi....again
I would like my bike to sit as low as possible but as a first timer I would like advice as to what people think or know is a safe ground clearance to build to as I understand the salt is not as smooth as it might appear in films and photos.
Thanks again
Peter
Peter, we may need more info... solid or suspension on the rear....
We ran the gsxr about 1 to 2 inches with the suspension set hard and damping at maximum.  Had over 180 lbs of ballast.... 380 if you count the rider  :-D
It lost a little bellypan paint when the crunchies were big
peterdallan
Apologies Stainless
Hard tailed frame with vintage Triumph Tele forks, so a couple of inches of movement up front. Based on a Triumph Thunderbird but lighter of course. Rider about 185 lbs
Peter
Weight is your friend at Bonneville, be sure to bring along some bolt on ballast.  Ballast = Traction
The numbers I gave you were for our partially streamlined bike.  Bounce the forks rider mounted, leave yourself about an inch of clearance.  The best bet is have a little adjustability, if the salt is bad you may need more clearance than when it is perfect.  You can let a little or a lot of fork stick our of the tree.
peterdallan
Ok thanks, that makes sense, I'll try to make sure I can adjust as necessary.
Thank you
Peter
Buzz Lightbeer
Peter will you be at the meeting next week?
Regards
Dave
peterdallan
bak189
If he is using a early Triumph Thunderbird engine, I don't think any ballast will be needed........50hp's maybe???..............sorry
Question authority.....always
Vinsky
At what horsepower range do you need to start adding balast? Or at what speeds?
Nortonist 592
Quote from: bak189 on January 24, 2012, 07:05:11 AM
I thought an early Triumph Thunderbird would be considered ballast.
Sorry.  I couldn't resist. : - )
Nortonist 592
Sorry Glen.  It was a bit like someone handing you a $50 bill.  It was irresistible.
OK, so maybe no extra ballast will be necessary.... Our experience was at speeds above 175, might not see that with 50 hp.
55chevr
Nortonist 592
Early Triumph Tbird.  HP in the 50s is about right if you want it to stay together.
