electric (or whatever works) fuel shut-off for motorcycles
Started by 2stroke, January 21, 2012, 09:35:30 AM
2stroke
Having never gone land speed racing, I'd like to be able to run my modified bike (Yamaha RD400) in both gasoline and fuel classes.  As it uses a standard gasoline tank with gravity feed to the carburetors, how do I go about putting together a handlebar mounted fuel shut-off system?  Thanks to any and all for your assistance.
saltwheels262
pingel offers a cable operated , handlebar mounted shut off and
petcock assembly.
website might be pingelonline.com
franey
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
55chevr
The pingel fuel shut off switch is simple and works ... they are not shy about the price ... Joe
salt27
wfojohn
Hi 2stroke. Welcome aboard. RD400 is a perfect bike, where are you located?
saltwheels262
Quote from: salt27 on January 21, 2012, 11:20:22 AM
I am considering using an electric shut off from a RV.
http://dan-marc.com/79-afc1231412.html
will it be able to attach to the fuel tank with an npt nipple ?
                            - franey  8/2007
ol38y
Larry Cason
2010 BUB 1350 M-PG record
salt27
Saltwheels,
Attaching with a nipple shouldn't be a problem as long as there is a bung in the tank for it.
Vibration could be an issue if the nipple is too long.
Ol38y,
1/4" is larger than the factory valve [350cc] and I was considering using two of them.
Thanks for the input, Don
I hope the web elf dosn't nail me for using nipple and bung in the same sentence. :-D
Nah, the words are fine in this context -- but your spelling did catch my eye. :evil:
MiltonP
Am I missing something humorous or are we intentionally delaying the response...you only need the ignition cut-off on the handlebar but you need to be able to cut off the gravity feed while seated on the bike?   :cheers:
ol38y
In SCTA at least, on a fuel bike you must be able to shut off the fuel from the bars...
Larry Cason
saltwheels262
Quote from: ol38y on January 22, 2012, 07:19:04 AM
included also-- lta , ecta & bub .
franey
                            - franey  8/2007
55chevr
I think you are confusing gas class rules with fuel class rules ...
MiltonP
OK...Missed that but I still believe that the bikes I looked at only had a remote kill for the nitrous and not the main tank which was still only via the petcock.  I didn't look at it that close but I just don't remember seeing a remote mechanical for any gravity feed tanks.
55chevr
