2 percent lanthalated tungstens.
Started by robfrey, January 22, 2012, 09:11:01 PM
robfrey
In taking the advise from weldingtipsandtricks.com, I tried these electrodes on tig welding aluminum. I was amazed. They do not ball up nearly as bad as pure tungsten. I thought that the balling effect was a good thing until I tried one of the 2 percent lanthalated trodes. Much better control of the arc and where the heat is going.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Vinsky
I use pure tungsten on thin aluminum, 2% thoriated tungsten on heaver aluminum and all other metals.
Kiwi Paul
I`ve used Ceriated Tungstens for both Aluminum and Steel for the past 6 or 7 years. Have never tried Lanthalated. Was told Thoriated were a Health Risk. Like welding isn`t.......
The ceriated and lanthiated tungstens are newer technology and work really well with the newer machines. I haven't tried them on my old Dialarc 250. I don't use puretung as it spits at very low temperatures. The alternative for aluminum is zirtung which balls similarly to puretung but is much more temperature resistant. The 2% Thoriated works really well for steel but is a poor choice for aluminum because of the way the tungsten is constructed. The zirtung or one of the newer alloys is a much better choice.
In theory thoriated tungstens give off radiation but there are a lot of us around who have used it on a daily basis for large numbers of years with no noticeable ill effects.
robfrey
2% lanthalated is hard to find. Most welding stores do not carry it. I found it at "the arc zone" using amazon.
My experience is that it works better (handles the heat) better than all other trodes but I have not tried the zirc trodes yet.
Weldingtipsandtricks youtube page does a pretty neat test using various trodes. Can't figure out how to paste the YouTube http address. You will need to search it.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Vinsky
Here's the utube link
http://www.youtube.com/results?search_query=weldingtipsandtricks+tig&oq=Weldingtipsandtricks&aq=1&aqi=g5&aql=&gs_sm=c&gs_upl=5755l5755l0l11330l1l1l0l0l0l0l318l318l3-1l1l0
I spent the better part of the last 35 years welding aluminum with 2% thoriated.
Don't know about radiation effects, but my arthritis is a daily reminder.
I enjoy Welding Tips and Tricks. There's a lot of good information there and some great entertainment.
Vinsky, next time you're at your welding supply store pick up a stick of zirconium tungsten and give it a try. I think you'll find it's worth it.
If you want a good source for tungstens as well as a pile of really good information you may want to try this website.
http://www.diamondground.com/
Vinsky
#7
I'm retired now so won't be welding much anymore. I probably have more than enough supplies to last me. I use my 1/4" tungsten for parallels
ls now.  These new tungstens do sound very interesting though.
