Second Wind: the 200mph Merkur
Started by 4-barrel Mike, February 07, 2012, 07:00:06 PM
4-barrel Mike
Is this a good height for the lateral head restraint, 3.A.3?
around ear height, with you -20 fire suit on
looks about right
4-barrel Mike
Thank you, sir! (both of you!)   :cheers:
Kiwi Paul
Mike..Do you need me to come and look? Sorry I didn`t get a chance to talk on Saturday.....
4-barrel Mike
Sure, if you want to.  :-)
Give me a call at your convenience.
It looks very nice.
I love your attention to detail. :cheers:
4-barrel Mike
Quote from: tauruck on May 26, 2014, 10:27:47 PM
It looks very nice.
High praise, sir! considering that my best looks like a two-year-old drawing on a wall with a crayon compared to what you're doing.
4-barrel Mike
Overkill?
Just under, as far as I can tell working alone, 4" wider than my helmet.
"Overkill?" ............ There's no such thing! Your cage is looking good.
4-barrel Mike
Thanks, Pete.  It was supposed to be slightly tongue-in-cheek.
Ok, next problem.   :-D
Left-side belt mount, as original, seems well-placed:
Right-side, as original, ok for the seat Rick used (shown above), but I'm sure that Grib set the seat on top of it.
Not enough room for the original-style tube:
So, I propose using a piece of 1/4" x 3" similar to the cardboard, fit to the trans tunnel, welded solidly to the front and rear crossmembers as shown, and stitch-welded to the trans tunnel:
And then weld on the double-shear mount.
I think that this would provide more than sufficient strength.
Any thoughts or other ideas?
Bob Drury
  Mike, it's looking good.  Just remember one caveat:  You want the tubing under the floor to be equal in strength to the cage over your head... people have exited out the bottom before.  Bob
Bob Drury
salt27
Mike,
  When positioning your belt mounts make sure the belts don't rub on the seat.
I remember someone having an issue with that.
4-barrel Mike
Thanks for the kind words and the advice, Bob.  The original longitudinal subframe was heavily reinforced by Byrnes & Co. and strongly ties into the Alston back-half, running directly under the seat:
Sorry for the angle.  Front is to the bottom (obviously).  Is that sufficient to keep me from falling out?  :lol:
Don, thanks for advice.  I expect that I'll have to trim the seat slightly to fit correctly.
