Help! Need Longer 8mm Blower Belts!
Started by 38flattie, February 27, 2012, 09:18:36 AM
38flattie
I can't find any 8mm belts longer than 70.55". I can't go smaller than a 53 tooth on the crank pully, due to the crank support.
Soooo, does anyone know where I can find a belt in the 72"-73" range?
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
maguromic
Buddy, Call Jones  http://www.jonesracingproducts.com/  They will make you a belt in any length and width (I think there max width is 2' :-o).  I would order a few extra to keep on the trailer.  Tony
johnneilson
Probably have to go to Gates for larger belts.
The next size is probably around 78" (2000mm)
I have seen some in the range of 140", and no, I don't stand anywhere near them.
38flattie
Quote from: maguromic on February 27, 2012, 09:26:47 AM
John, Tony-Thanks!
Tony, once again, you're a life saver! Jones is getting us the belts we need!
