M-G CBR1000F
Started by DavieB, March 04, 2012, 11:22:13 PM
DavieB
I've been on here for a little while and though i should start a build thread.
My dad's building a streamliner so for shits and giggles we've decided to use his left over parts (and a fair few that weren't left over  :evil:) to build a bike to race for myself.
The highest part of the bike is the top triple clamp at just under 900mm (using standard vfr400 forks we had lying around, same DIA but around 125mm shorter) my whole body is pretty much level with the top triple clamp and my head is just high enough to see over it.
it doesn't run a radiator, under my seat is a coolant tank and its setup to only draw water as it needs it (i expect it to get reasonably hot under my arse :-o). we decided to get rid of the radiators because we want this engine to run as close to how it will be running in this bike as it will in the streamliner. The fuel tank is the small tank you see in front of the tank I will be sitting on. it hold enough fuel for us to do our run but will probably need to be refilled between runs. behind my arse you see all the electrical stuff, the battery is the one out of my road bike, there's a data logger with a wide band o2 sensor to help us set the bike up, an Ignitech ignition with a custom ignition map in it, and a tip over sensor that cuts the fuel and spark if the bike leans over more than 45 degree's, that's only on there to make sure that the vibrations of running on the salt doesn't piss it off too much (more testing for the streamliner :roll:) other than that it's a pretty stock standard 1987 cbr1000f, it's been a bit of a spur of the moment job we only decided about 4 weeks ago that we were going to run it, before that it was just a frame. we robbed the engine back out of the streamliner, assembled the bike and started cutting things off it.
This is what we are testing all the bits and pieces for, once i get some more photo's of dads bike I'll see if he will let me start a build thread.
oz
Excellent pleased to see another CBR doing the LSR thing the streamliner is looking good hope the carbs are ok,nice tail section I am going to have to use Aluminium on mine as I cant do glass work....Yet
Tell yer old man I almost have the Injection sorted.
Best of luck Dave.
Oz
donpearsall
Davie,
Thanks for the build thread. Good luck with the project. I ran a no-radiator coolant tank on my turbo Hayabusa for 2 seasons and it worked great. No overheating at all.
What venue are you going to run it at first?
DavieB
Hi Don
Thanks for the info, I've been thinking about how warm I'm going to get but I think with some insulation and the seat myself and the coolant tank I should be ok, I shouldn't need any thermals under my leathers anyways  :-D . I live in Australia so the bike will be run at Lake Gardner.
Oz, dads really happy with the carb's, im pretty sure he has them on another 1000f at the moment while he is making a base curve for the ignitech.
DavieB
I have not made a lot of progress but I thought I would do an update.
After fiddling around with some spare parts I had left over from an old project, reading and re-reading the rules. I've changed the headstock angle 3 degree's and extended the swingarm 85mm to take me to 10mm under the 10% over stock wheelbase rule for my class.
I've moved the front wheel to make room for my turbo I hope to run soon, and moved the rear wheel back to help make the rear of the bike a streamline as I can.
*image shack is not working on my phone, sorry*
DavieB
DavieB
Not a whole lot new to add.
The frame, swing arm, subframe, and tanks are all at the sandblasters at the moment so I have been doing little odd jobs until I get them back.
I have a few pics of the exhaust getting wire brushed, painted then wrapped, I will attach them tomorrow my phone is being a pain.
The bike will be running in a different class now after I found some Charlie Toy bodywork cheap and decided to set it up from the start with methanol.
I'll throw some photos on here tomorrow. :-D
DavieB
The exhaust after wire brushing and changing the collector
After painting
After Wrapping
The triple clamp before
After
It helps to locate the pegs so you are not all scrunched up.  A fellow is not as flexible when wearing leathers.  Also, a guy gets older.  My bike is set up how I was comfortable eight years ago.  Its a bit of a tight fit now.
DavieB
Quote from: wobblywalrus on December 10, 2012, 09:00:35 PM
My pegs will be moving now to suit my new body work.
DavieB
Slowly coming together after sandblasting and painting  :mrgreen:
DavieB
Forks back in and sitting on the ground. (thought I was going to break the cloths line if I kept going)
Old Scrambler
Just a thought.............about the wrapped pipes.........the wrap seems to make them look slow and will catch salt.
DND
I was just wondering what the pipe wrapping does for you.
Thanks, Don
fredvance
Wrapping keeps the heat in the pipe, prevents the pipe from disapating heat. The exhaust flows better with the pipe hot.
