Help on drag tires for MC Bike
Started by Anchor, April 15, 2012, 09:35:47 PM
Anchor
I'm entering a lil'moped in the A/G 100cc class and need H rated tires 2.5X17 front
and rear, anything wider would hit the drive chain, I was looking at the
Goodyear D1445 front runner drag tires, and a little confused if these would pass
tech inspection, any advice would be appreciated. I'll try and post a pic.
Dakzila
What venue are you building for?
What is the A/G 100cc record at the location you'll be running?
Buzz
Anchor
The venue is Bonneville Salt Flats , The A/G Record is 99mph.
I have S rated tires (113mph) but was told I need an H rated tire
by one of the officials.  I don't see any written rules in the 2012 book, but
read on a forum that the Goodyear drag tires cannot be used on rear wheels,
still waiting on confirmation.  I saw a hoosier tire 2.5 X 17 but I imagine they
might not pass either for a rear.  I have seen some 17's rated H but none so
far will work on these moped rims.  Any advice ???
thanks
-Todd
sabat
I wonder if a slick from the front of a 125cc road race bike would be skinny enough?
Anchor
I researched 125gp tires but they seem a bit too wide. Plan B is switching to a
18" rear, Emot racing have some 2.25/2.5's x 18 H Rated, then just use the
goodyear drag for the front 17"...
BHR301
#5
I may be missing something...but as I read the rules..you can't run a tire designed as a drive tire for a drag race vehicle (a drag slick) but I found nothing saying you can't run something like the GoodYear front runner on the back of your bike. I just checked and the BUDDFAB streamliner is using GoodYear front runners both wheels..
Dakzila
I'll research it a little more but I'm sure you're OK with an S-rated tire for a class record under 100 MPH.
Buzz
Anchor
#7
Thanks Buzz !,   I emailed Matt Shuss about the S tires but he said anything under H is not recognized and would
put the S rated tire at 70mph limit.  I realize that it a safety concern but was a little confused by the fact that
the rule book states your tires should be rated to the record in the class, I guess the two rules run together when
it comes to checking the ratings. I'm might try the Goodyear front runners put I'm concerned they may not fit
my rims properly...more research...
-Todd
Dakzila
Well Matt is the final say!
I've used the Front Runners on 1.85 rims with no problems.
You might also check out Avon Speed Masters.  I have a set of Avon Speed Master 275/300X19" on my bike and I'm running a WW1 rim.
Not sure if Avon sales a 17" Speed Master but it 's worth checking.
Good luck,
Buzz
Anchor
The tires currently on the bik are 80/90-17", how would you compare
the width on the good year front runners is it actual 2.5 width?
The max width I could probably go is 2.75. Appreciate all the info!
-Todd
Dakzila
Check out the Bridgestone Battlax H rated bias series.
There's a 100/80-17H tubeless tire that fits on a 1.85 to 2.75 rim.  These are front tires but you could run a front on the rear. Maybe these will fit.
Here the link to the Bridgestone page:  http://www.bridgestone.com/products/motorcycle_tires/products/battlax/bt39.html
BT-39 Front tubeless H rated
TIRE SIZE REC. RIM (inch) MEAS. RIM (inch) OD (mm) TW (mm)
 100/80-17M/C 52H TL 2.50 1.85 - 2.75 594 101
 110/70-17M/C 54H TL 3.00 2.75 - 3.00 587 108
 110/80-17M/C 57H TL 2.50 2.15 - 3.05 614 113
Buzz
Anchor
All these tires are good options but I just heard back from the rules chair...
"Any tires that are specifically constructed for "front fitment" only would not be allowed to be used as a drive tire."
saltwheels262
sure seems to be a lot of front runners on the rear.
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
Dakzila
Quote from: Anchor on April 17, 2012, 06:47:45 PM
Lots of smaller bikes are currently running front drag tires on both ends???????
Buzz
I don't know (as most of you well know), but are these tires marked "front"?  If not, how can they be excluded as drive tires (for a wheel-spinning at 200 MPH 100cc open bike)?
