Honda CBR 600r Turbo carb project.
Started by Jimiset, May 01, 2012, 07:49:33 AM
Jimiset
Hi there, i am in the process of a turbo project for my carburated Honda cbr 600. I am trying to find some information (kind of a list or chart) about carburetors,  since i want to change the 4 little carbs for a single bigger carb, which would support a suck-through turbo setup. I was thinking that a Mikuni 4?mm would be ideal for the displacement of the engine, i just don't know if there is something special needed, like seals or jets for the carb. Also, for the turbo i have 2 choice, a RBH31 or a TD02, i'm not sure again if one would be better for that kind of setup. I heard the RBH31 would need modification for suck-through, does the TD02 would need that kind of work or a stock one would do the job? I have read a lot, but its hard to find the specific info, if someone knows, that would be very helpful, thank you.
Play hard or dont play at all....
Jimiset
Thank you for the advice Scott, ive been reading again, and I think i'll go with a blow through. The project is for drag racing, ive been drag racing in cars for a while and ive developped a new passion on two wheels, and I'd like to try that on a dragstrip.
