500 PP class rule questions
Started by MJ Williams, May 02, 2012, 07:39:57 PM
MJ Williams
My uncle asked me to post up a couple questions concerning some clarification on the rules for his 500 Suzuki in the PP class.
Can he cut a couple inches off the stock handle bars or replace them with something lower and narrower as long as they use the stock mounting location and stock controls?
Lower the ride height on the bike by changing the link in the back and using a strap on the front or modifying the fork internals.
Mill the stock head.
Change the cams
Thank you for you input.
MJ
Nortonist 592
Looking at the rules on the BUB forum it seems that all the mods you list are legal.  This was typed on a keyboard not carved in stone.
fredvance
I am pretty sure you cannot lower the bike in production. You can't in SCTA.
donpearsall
Here is the link to the AMA rules used at BUB
http://www.speedtrialsbybub.com/2012_event/2012-AMA-BUB-SR%27S-FINAL.pdf
Fred is correct that you cannot lower the bike. It must be stock height, which is usually measured as the published ground clearance.
You can alter the handlebars according to these restrictions:
"Handlebars are restricted to 15-inches above, 4-inches in front of original mount or 4-inches lower. All handlebars that mount to the original mount and meet the criteria in this section are acceptable."
But you wanted to make them narrower which would not be allowed.
Engine changes would be allowed as long as they are not visible and the stock displacement is not altered.
The current 500cc PP record is 112.476 mph so that should be do-able.
Good Luck,
tomsmith
Maybe you could move the handlebar grips inboard and let the ends stick out.  This would get your arms and hands inboard a bit and still have "stock" handlebar width.  The handlebar ends would have a lot less drag than your elbows sticking out in the wind.
139mph with no bike, but with speedo and helmet.
RansomT
The way I read the rules for Production is even more restrictive than SCTA or ECTA.  Chapter 4 states:
Production class motorcycles shall not be modified from Original Equipment at time of manufacture. e.g., frame, forks, gas and oil tanks, seat, front and rear lighting, fenders, wheels, brakes, air intake box and (unmodified) exhaust system. They shall also contain the engine that they where originally produced with.
I think that is why they call it production instead of modified....  :roll:
Keep changes out of sight... internal are legal, external are not.
RansomT
What I am referring to is that the rule specifically states unmodified exhaust.  It doesn't matter if it is out of sight or not, if it has been modified it is illegal.  Well at least the way I read it.  :-)
MJ Williams
The rule book does state an unmodified stock exhaust. That does bring up a couple question for me with newer bikes in the PP class. Like how does the catalytic convertor survive the rich fuel mixtures and race fuel? Also as far as unmodified, there were some bikes in the PP class last year that seemed to have real loud exhaust noise. A couple BMW 1000RRs and a certain CBR1000 Honda come to mind right off the bat. They sounded like they had race systems on them, you could hear them shift into each gear at the start line of the long track. Whereas similiar bikes in the PP class you would not hear the exhaust after the 3-4 shift.
fredvance
Read all of the first paragraph. You must keep the exit orfice the same as stock. What you can't see,  you can change.
RansomT
I am acquainted with a couple of teams that ran BUB last year in what they called Production.  Seems that there is a class for a Production Motor with a Modified Frame.  The Modified Frame in this case also refers to the exhaust.  So the old drag race class of Production seems to match what they could do.  I, personally, found exception with calling those bikes "Production", but it's in the BUB rules that way. So....
Both Fred and I have ran Production under SCTA and ECTA rules, which is where the bike must look as if it rolled off the showroom floor, but with modifications out of sight.   Some classes of BUB are not that way.
fredvance
Out of sight modifications, me?? :-D
saltwheels262
Quote from: RansomT on May 10, 2012, 11:56:05 AM
production motors with modified frames maybe a thing of the past.
check the 2012 rules before proceeding.
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
RansomT
Quote from: saltwheels262 on May 10, 2012, 07:32:34 PM
I was just going by my experience from last year (2011).  Yes, I agree, always check the current year rule book.
AHG
"UN"- The opposite of (e.g.-Billy's exhaust system remained "un"modified, and or in original state in its entirety
so he could compete in the Production class, and be at ease while in impound.)  :-)
~ I CAN COUNT MY LIFE ON ONE HAND ~
Faith, Family, Friends, Fun & Fast Motorcycles
