2% Triumph 98% hard work
Started by Frenchinjection, May 07, 2012, 03:30:31 PM
Frenchinjection
Supercharged intercooled methanol 750, Slider clutch, billet crank, billet gearbox box.
Dakzila
Nice!
Coming across the Pond in August?
Buzz 1513B
Old Scrambler
You won't need the front brake......but you MAY need a chute :roll:
thefrenchowl
 :wink:
And I thought I was the only French madman in GB...
Patrick
Nortonist 592
Now you might start to feel normal Patrick.  : - )
Nice bike.  There is a lot going on in the older bike classes.  All sorts of fresh thinking and new builds.  It will fit right in.
Queeziryder
Quote from: thefrenchowl on May 07, 2012, 08:47:17 PM
:wink:
Patrick
Hi Patrick
French by name not nationality
Neil
Fellow drag racer and Kawasaki breaker
Old enough to know better, but too interested in speed to care
thefrenchowl
 :-o
Thanks, I feel better now!!!
Patrick
Briz
Hi Steve. So thats what you've had up your sleeve!
Lookin' good.
Running yet?
beerbellykelly
strewth!! dave has cleared his drive!!
that looks bitchin'
well done dave n steve-
-we just extended our front mudgaurd down as low as we cud , keeping the salt off is a battle.
so when does it run?
we,d love to see the spec written up here , gearhead central.
GOD BLESS THE HUMMIN' CUMMINS
www.jamesandfriend.com
desperate
Looking good matey, I'll see you at the container depot in June......we're bringing 6 bikes over from the UK for Speed Week. :-D
Don't push me, I'm close to the edge.
pipehack
 New guy here, I'm a Brit bike guy myself. Sorry guys about bumping this thread up to the top. I had to say something. If this was a no no, please let me know.
Old Scrambler
Do you live on a boat? No problem with bringing an older thread to life. We would all like to know what happened to this build.
Hoody
It ran and was shown on the "speed dreams" program that was made by the BBC (should be on youtube still?) iirc a part of the blower (one of the few parts they didn't make themselves?) failed and they couldn't get a replacement?
Frenchinjection
Guys, we were back on the salt for 2013 Speed week and ran several passes in the high 150's.  Exit speed of 158.  We could not run faster as we had oil pressure problems.  The record of 140 still stands as we did not go into impound to try and set it.  We needed track time so we went around and around testing and finding all the gremlins. One gremlin was a split block.  Cast iron is not good enough for this sport, so for 2014 we are building a steel block.  We will be back for 2014 along with around 14 other UK bikes.
PS, the blower failed in 2012 because of a design problem by us.  If you have an intercooler, which we do, then you should not put fuel through it, if you have a screw blower, which we had, then you must put fuel through it else it over heats and seizes up.  Guess what, it siezed up.
For 2013 we had a Rotrex C30-94 centrifial blower.  It worked well enough.  30 psi at 6000rpm, we can rev to 8.   Intercooler ice tank was increased in size from 1 gal in 2012 to 5 gal.  We can get 20lb of ice in it. The Intercooler after the run is ice cold so it is working.  Runs with and without it show a marked drop in power if you forget to turn the pumps on.
I am building a web site with the build from 2011 to date and will update it when I can.  Currently there is only a holding page with a pic of the bike on the salt 2013.  url]http://www.saltbike775.co.uk[/url]
I think with the bock and other work, it should be 1% Triumph.
