Wilmington 6/2/2012
Started by Moxnix, June 02, 2012, 06:48:03 AM
Moxnix
We are here, have audio ouput, mostly the CB channel, with a little honky ton, blue grass, and blues in the background, when I can get the speakers to work.  I hope someone is posting picturtes.
Moxnix
"meridix" in your search engine gets to our webcast host.  On their homepage, search for "Landracing" and today's live link should come up.
Geo
Sitting here in Prairie Village, Kansas listening to LSR in Wilmington, Ohio.  Someone just went 192!    :-)  and another at 179.725  now 3232 beginning the run and through the lights at 136.650.
Thanks Moxnix!   :cheers:
The Landracing logo is on the front page of meridix.com
I do not know if this link will get you there:
http://www.meridix.com/everywhere.php?liveid=Landracing
Moxnix
My background audio is cutting in and out.  But the CB seems to be strong.  The mic I brought is not omni, multi-directional, and is not picking up the engine sounds through the timing lights.  Something else to find at a pawn shop or on Craigslist.  Piedmont blues cutting in and out.  Gack!!!!!!!
RacerX9623
Thanks for this. I am stuck at home wishing I was there. At least I can listen . Suprising how many numbers I recognize. This is fun
trying to go 200 KPH with a 250cc four stroke.
BudJ63
Next best thing to being there!
Del and the Black Lightning 1952...  on audio
Moxnix
Was glitching on Del and The Boys.  I'll play it again and then switch to Milwaukee Midgets band, Honkytonkitis....... Wind picking up, shut off the mic to avoid that noise, here we go again....
BudJ63
Sounds better.  Just a little static hum.
BudJ63
#9268 ...........155.084mph
#7230............85.627mph
#9885............142.935mph
BudJ63
#9391............143.526
#9258............133.787
#1223............133.700
#9198............086.597
#1271............133.435
#1661............144.552
#9148............199.556
#8530............135.197
#6508............162.951
#9500............    Audio died
Geo
Audio good here.  Stopped to pick up debris.  :-)
Captthundarr
Souds pretty good down here Moxnix. Here goes Das Bullet. picture a little fuzzy though. 191.653 for da bullet. :cheers: working on Amy's car not the race.
Moxnix
I switched out the single JBL speaker for a set of JBL stereo speakers and still pick up the hum.  Twisted all the connectors, piddled here and there, still can't remove the buzz in the audio.  Had the 3G hotspot stop working for awhile, had to reset all three laptops.
Beautiful weather, winds died down from a buffeting head/side wind.
I should have brought a multiple CD changer instead of this old Nakamichi single player.  Oh, someday it will work fine and keep going all day.
Max -
Try switching the ground lift on the AV1-A.  Sounds like an isolation issue.
Oh, also, check to see if there is a ground lift switch on the mixer you're using.  It's a Realistic, and I believe it's made by the same folks that make the Gemini mixers.  The ones I have at work have a ground switch.
