fork pinch bolt safety wiring
Started by JoeRider677, July 01, 2012, 12:04:18 PM
JoeRider677
Any simple way to safety wire the pinch bolt on the front fork when the top of the socket head pinch bolt is flush with the surface of the fork?
Foil Hat Racing
Bikes Built Better
SCTA Records 2011   ECTA 2013
MPS-BG   120.507     M-BF 140.507
MPS-BF   141.236      M-BG 146.19
M-BG      118.674      MPS-BG 165.01
M-BF      132.905       MPS-BF 170.32
LTA 2013
1 mile - MPS-BG 174.341
1.5 Mile-MPS-BG 184.09
ECTA 2014
M-BG 155.38
M-BF 149.00
MPS-BG 175.57
MPS-BF 186.877
How hard do you practice when no one is watching
saltwheels262
you could use a .125" aluminum spacer under the socket head
and get a .125" longer bolt.
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
runt13
i put nice ss socket head lockwashers under the bolt heads and that gave me enough room for the safety wire holes.
who would have guessed it would take so long to go so fast for such a short time?
2012 Wilmington mile
April meet,
p/pp-1350/4 record, 132.601mph
September meet,
p/pp-1350/4 record 139.915mph [bump]
p/pp-1650/4 record 142.364 mph
p/pp-2000/4 record 140.009 mph
p/pp-3000/4 record 144.511 mph
2013 Wilmington mile
July meet,
m/pg-1650/4 record 137.278
m/pg-2000/4 record 136.695
Sept meet,
p/pp-1350/4 record 141.1986 [bump]
2014  Wilmington mile
May meet
p/pp-1340/4 record 142.5855 [bump]
JoeRider677
I'm going with the spacer so the socket head is out enough to drill and safety wire from there.
Foil Hat Racing
Bikes Built Better
LTA 2013
ECTA 2014
M-BG 155.38
M-BF 149.00
MPS-BG 175.57
MPS-BF 186.877
grumm441
If it goes right thru the fork, you could put a longer allen screw in and lockwire the other end
But use a stainless allen screw as they generally have 10mm more thread on them
Joe Timney
Safety wiring of pinch bolts is NOT required by ECTA. The axle/nut is required. On Busa style axles, you need to secure both ends as the axle can screw out even if you wire the nut.
Joe Timney
Retired President of ECTA
www.delawarechassisworks.com
Dean Los Angeles
The rules require certain items to be safety wired. That is simply a base point to start. You have to decide what bolts you don't want to fall out, and it's a lot more than the rules require. I'd safety wire the pinch bolts.
Plmkrze
Quote from: Dean Los Angeles on July 02, 2012, 07:11:06 AM
I would like to thank JoeRider677 for starting this thread. I am not a cycle guy (small stones, but i digress). Dean's reply hit the mark with me. I have to decide which bolts I don't want falling off.  As I look at my car I have to make a concerted effort to safety wire/castle nut/cotter pin etc everything (within reason) that I don't want falling off. Thanks!
"Trim it, whittle it, make it work."
East Coast Cherry Pickers Association (ECCPA) and proud of it!
JasonS
I have read the rule book many many times, and the only thing I have found that is REQUIRED to be safety wired are the axles. Is there anything else that I'm missing? It's not that I won't wire more than that, I just want to be certain I get everything needed.
JoeRider677
Jason, The rule book does say that the axles do have to be wired. My case was a little odd in that bikes bike in question does not have the standard axle nut arrangement on the front. It's a 2011 Kawasaki Versys and everything is flush. If you can not wire the axle and nut the next best thing is the pinch bolts. What I ended up doing was using a longer pinch bolt and a spacer just long enough to have the head of the socket headed bolt protrude out for a safety wire hole and the wire to go through. The ECTA has a page on facebook and I ended up posting pictures there. If you've got facebook look me up, Joe Heffernan, go to my photos, albums, find "mobile uploads", the one with 74 pictures and scroll down. the first and third pics are both sides of the fork before and the middle pic is what I ended up doing.
Foil Hat Racing
Bikes Built Better
LTA 2013
ECTA 2014
M-BG 155.38
M-BF 149.00
MPS-BG 175.57
MPS-BF 186.877
RacerX9623
The 250 ninja uses cotter pins to secure the front and rear axle nuts. They are good for tech.
trying to go 200 KPH with a 250cc four stroke.
relaxedphit
Though it''s not required anymore, I'm a fan of safety wiring the oil drain plug and filter.
