question on classifcation of the car I want to build
Started by CGoodson, September 11, 2012, 06:36:45 PM
CGoodson
I want to build a Ford Pinto with blown Hyabusa motorcycle engine. Is there a class or what class would that be? The pinto can be a classic but, I don't see any motors smaller than a F in the classic blown fuel altered class? What do you guys think? I appreciate any feed back. :cheers:
Corey Goodson
cgr138@gmail.com
hptt:www.facebook.com/corey.goodson
1000 Bockscar Lakester H/BFL Red Hat record 233.119
Currently Building #1177 G&S Roadster H/BFR
RichFox
That is the rule as I read it. Engine classes from AA to F. Pretty clear. I guess you would be on BFAlt. No Classic.
SteveM
How about running 2 Hayabusa engines to get into F-class displacement?  SCREAMING.
jimmy six
streamliners only for multiple engines.........in the book
SteveM
Ooops, I guess you will have to weld the 'Busa blocks together.javascript:void(0);
CGoodson
You can buy busa's as a V8 now! That would be a good power plant
Corey Goodson
cgr138@gmail.com
NathanStewart
classic would require no efi (or that stock pinto efi if it ever came with it), distributed ignition, and carb or mechanical injection.  plus, i saw a proposed rule change that would outlaw bike engines in classic.
so yeah, sounds like regular ol' altered is it.  not sure if a pinto would be very competitive without being in classic.... or you can just be into it for the fun so who cares at that point.
El Mirage 200 MPH Club Member
