1935 chevy 2 door or 4 door sedan for LSR
Started by lsrhayseed, September 17, 2012, 09:03:05 AM
lsrhayseed
I do need lots of help.I have 2 options here. 2 door or 4 door sedan.Can I get some insight from you guys on what to build...Plus for what class.I want to run a fenderless car.  thank you all in advance for your help>>>
RichFox
Fenderless it's going to be an Altered or Comp Coup/Sedan. Up to you. Do you have a rule book?
lsrhayseed
yes i do have a rule book...isnt the altered class limited on engines...like no aftermartket turbos..this rule book isnt the easiest thing to read...looks to me that there are atleast 6 class' for (pre-1947) a roadster...& 2 for a(pre-47) coupe or sedan...in comp class you are giving up aero to cameros & mustangs..Am I wrong..I could stand some input.Out of 60 some people looking at this post..Only 1 replied.please...share your knowl how guys....again THANK YOU TO EVERYONE IN ADVANCE
RichFox
What kind of engine are you planning on using? If you want to run in the XF or XO classes, no turbos on vintage engines in vintage classes. If you are planning on a newer engine and you want to run a turbo, have at it. Puts you in Blown alt or Blown CC
lsrhayseed
I understand the xo & xf...but my 2012 rule book isnt clear on  the "alt" stuff. Can I run a twin turbo LS6 with an after market EFI. lets say either body in CBFALT or CBGALT? wont this be running against say a 1969 to 1981 camero that clearly have an AERO advantage..  again THANK YOU
kiwi belly tank
You need to clarify what you are planning here to get advise, 2dr or 4dr what?  So are you looking to just run or are you looking to hunt a record. If it's the latter, choice of vehicle is very relevant. It's not likely you could turn up with a 34 Chevy sedan thats about the size of an appartment building & expect to click off a record.
A lot of savvy people have spent a lot of time putting records where they are.
RichFox
#6
Yes you can run it and yes the Monzas and Vegas and Cameros will have an areo advantage. 5.C in the rule book is fairly clear. No aftermarket EFI. in the "Classic Category. The LS6 and turbos are fine but you will have to run in plain old Alt or Comp. if you need the EFI.  Against 2012 bodies if someone wants to run one.
lsrhayseed
could you be more spicific about this comment please"The LS6 and turbos are fine but you will have to run in plain old Alt "  can i run any(aftermarket) turbo charged & EFI engine..the 2012 rule book isn,t all that clear to me on sedans....it says "cbfalt,cfalt,cbgalt,cgalt,and so on..infront of all these it say "coupe".......again  thx
RichFox
The first letter "C" refers to Classic either Alt or Gas coupe or sedan. But there is also Altered class which allows later model bodies and/or aftermarket EFI. So if your car can not run in Classic Alt because of your EFI it will be put in Alt where the record is 10 mph slower anyway.
lsrhayseed
lets start with a 34 chevy(fenderless) sedan + big engine+2 turbos +trick EFI system(to keep the 1st 2 from melting)add that up....=  is there a class for this combo? that doesnt have late model bodies in ...
RichFox
No. You would be in Altered Coupe and Sedan. Any closed non sports car from 1928 to 2012. If you want to run in a class that is restricted to pre 1948 bodies you must run a Vintage engine within the X engine rules. You can run mechanical fuel injection in Classic. I don't know what is in the Kugel LeFevers Firebird. But I think it was Hilborn injected last time I saw it.
