dumbest question ever.....sorta.....
Started by Jonny Hotnuts, September 18, 2012, 09:33:18 PM
Jonny Hotnuts
So I cut my oil filter open to see what was in there but its tough to see the particles in the oil (*not that there is a bunch of stuff there). There are some tiny suspended bits and some grime at the bottom but its hard to look through 2" of oil (about 1 cup total oil).
Is there a good method for straining the oil through a very fine media or other method for observing the lions share?????
Just wondering.....
~JH
jonny_hotnuts@hotmail.com
*Andres Segovia
Tman
If you really want to know, find a local testing facility. I have been privy to info from some folks I know that run Harleys. It is amazing what you can predetermine with constant testing.
maguromic
I always put them on slides and look through a microscope, you will be surprised what you will find. Nothing dumb about the question, everyone should do it after every run. Tony
grumm441
Try one of those white paper conical coffee filters
saltwheels262
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
stay`tee
pour your used oil into a flat based container, (like a large oil catchment dish, as avilable from any performance aftermarket store),, let the oil settle for a cuppla days,, the heavy particles will settle to the bottom,, take it out into the sunlight,, sometimes it`s a bit scarie what ya can see, :-o
a pice of bright finished metal in the bottom of that pan will help!
It is a good idea to save the remains as a reference for comparisons with later samples.  This will tell you what debris is normal and what is not.
