ceramic wheel bearings
Started by Fheckro, October 01, 2012, 08:32:28 AM
Fheckro
Anybody have a good sorce for ceramic wheel bearings (car)?
9479 Monza C/CGC
Current record Holder @ 180.000
maguromic
I have used these guys  http://www.performancebearing.com/index.html  but hold on to your wallet, ceramic bearings for cars are expensive.  Tony
Dean Los Angeles
Fheckro
9479 Monza C/CGC
runt13
who would have guessed it would take so long to go so fast for such a short time?
2012 Wilmington mile
April meet,
p/pp-1350/4 record, 132.601mph
September meet,
p/pp-1350/4 record 139.915mph [bump]
p/pp-1650/4 record 142.364 mph
p/pp-2000/4 record 140.009 mph
p/pp-3000/4 record 144.511 mph
2013 Wilmington mile
July meet,
m/pg-1650/4 record 137.278
m/pg-2000/4 record 136.695
Sept meet,
p/pp-1350/4 record 141.1986 [bump]
2014  Wilmington mile
May meet
p/pp-1340/4 record 142.5855 [bump]
1212FBGS
Dave at World wide has been doing my bearings for a very long time.... He is a great guy and knows his bearings....  http://www.worldwidebearings.com/    Tell him i sent ya....
kr
Buzz Lightbeer
Big Dave Conforti at Worldwide Bearings. I've been using his products for 10 years now, never had a failure.
This man knows his products give him a call or email.
John Noonan
Yes get with Dave and Laura from Worldwide Bearings..they rock and have great products and service!
wfojohn
One more vote for Dave Conforti at Worldwide Bearings. Been using his ceramics for many years in our bikes. Its like working with an old friend, and service is fast.
John Ritter
Vintage Porting
rouse
I just got two sets of Bearings in from Dave @ WWB for the hub center steering units I'm designing. I called him on Wednesday and the bearing arrived to my shop on Monday. I don't see how anyone could ask for anything better than that.
Now I just need to get more chips in the pan so I'll have some parts to fit them too.
Rouse
Johnnie Rouse
Hellcat Customs
Thinking about going this route myself... my question is has anyone made this change and no others and how much faster did you go... I've always seen claims that road racers are faster with this swap in bearings but because I've never seen an isolated change I'm having a tough time deciding if it's for me or not
rouse
I chose to go with ceramic bearings for safety reasons. The speed rating is much higher than steel bearings, and ceramic don't rust.
The way I see it, if they roll out better with less friction, that's just a bonus, but not the primary consideration.
If it's safer, I don't care so much about the cost.
Rouse
Johnnie Rouse
Dean Los Angeles
ABEC 7 steel roller bearings will run 60,000 rpm. Front wheels don't run that fast.
If rusted bearings are a concern, the only way the bearing can rust is to get water inside. If water can get in, so can any foreign object.
The ceramic bearing won't rust, and is certainly harder, but foreign object damage can still happen. Steel or ceramic the bearing has to be protected.
So that leaves us with the speed question. Before you dismantle your old setup with steel bearings, do a spin down test.
Then put in the ceramic bearings and do the same. Spin it up, go get a cup of coffee and sit back, it will take a while.
rouse
Moisture is the big thing when washing salt from around bearings, even with the best seals. Size matters when speed rating comes into play, 60mm X110mm X22mm steel bearing are generally good to or around 6,000 Rpm when new. Who knows what that rating is, after they get a few years on them. Your right; you Probably will not turn the wheel that RPM, not even half that, so RPMs. are not the only consideration.
Safest bet for high speed over long distance is ceramic, "Hands Down". I have lost steel bearings at speed, "once", it want happen again.
Johnnie Rouse
Hellcat Customs
Ok so since we are currently turning low speeds it wouldn't be a needed swap at this point... when we get to the point of higher speeds that's where the safety nature of the bearing shines a bit more
