Caster angle
Started by restless1, October 21, 2012, 10:41:08 AM
restless1
Just wondering what guys run for caster angle on a belly tank?
Tman
There are a ton of discussion on here. Spend some time digging around. (thats what I did/do) :cheers:
restless1
yeah ive noticed, seems guys are all over the map with ideas. was kind of looking for a nice starting point. thinking of trying 15 deg.
#3
Circle track guys put caster in cars to "WEIGHTJACK" the cars off the corners--- is this what you want?  Caster will change the bite of the rear tires side to side-- when you make steering corrections!!!  There may  :?  be  reason why most hesitate to STEER at B'ville
John Burk
I'll add a question . For lsr what are the disadvantages of too much  caster ?
thundersalt
Quote from: John Burk on October 21, 2012, 03:23:51 PM
Bumpy return roads=lost thumb nails
916 REMR
El Mirage 200 MPH Club
Tman
restless, I will tell this, I am new and building my lakester. I STILL do not know what I am doing for caster yet. Will soon, front end is going together shortly. Good luck :cheers:
When we built the Bockscar we picked 37 degrees, basically what the rails were running.  It went straight, quite a bit of pressure was required to steer at speed.  Was that way for about 26 years... we broke an axle last year, decided to build a new one for this year.  The new axle has about 14.  Steering is definitely different... there is a lot less pressure required to steer.  The flopper is gone, it backs down the trailer easier, and pushes by hand a little straighter... at 37, once the front started to flop, it went.  I made a couple of passes before Pork Pie took the reins, I like it at 14 but I may add a reversed quickener to allow a little more wheel movement.  It seemed to steer too easy.  :-o  Pork Pie had no trouble keeping it on the track, even with the cross wind that popped up during his last record run.
Pick a number... 0 to 37... all have been used, these days I would say 37 is too much... 10 -15 is where I would land.  Just remember caster is not your only variable, pay close attention to scrub radius and bump steer
Dr Goggles
Ours is 30deg. We ended up with that because the guy who'd built ours,Graham Robinson, built one for John Lynch's bellytank at 23 and he suggested we go to 30. It doesn't "flop" , runs really straight...unless the motor is shaking itself apart, the wheel alignment is right and  so on.....
Stainless has the comparative view, 37 to 14 , everything else is subjective.
restless1
Thanks for the help..Im thinking Ill try 15 deg.  Ill be using model A spindles and hubs,  whats the fix for correcting the scrub.  Im looking into the 20:1 rack and pinion from Prowerks for the steering.
Quote from: restless1 on October 22, 2012, 06:11:12 PM
Wheel offset is the easiest way.
You might have trouble with the 20:1 r&P from Pro Werks as I think I bought the last one several years ago for my lakester. Check with them.
JimL
If building with a straight tube axle, you can make saddle clamp mounting with one cap slotted for a locater stud (with locking nut) in the tube.  You'll be able to quick adjust your caster, within reason, to see what works.  We wound up at 14 degrees on a 156" wheelbase mod-roadster.  Worked fine up to our best speeds around 185.
We did aluminum hubs with close-in wheel flange to correct scrub and keep bearing load points happy.  It will also give you some bearing choices if you make your own hubs.
Richard 2
The Chassis shop has 20:1 r&p's
4 cylinder Esslinger
Could of had a V8
restless1
Thanks for the tip..Ill give them a call........ and thanks to all the others for the ideas on the caster angle.
