Motorcycle: Front Brake required?
Started by tylerm, October 26, 2012, 07:58:51 PM
tylerm
I have a couple LSR bikes I have run at Speed Week the last few years, and I want to bring one (or both) of them to some ECTA meets in 2013. Neither has a front brake. Is one required to race at Wilmington? How long is the shut down? I couldn't find a course map on the ECTA website. Thanks in advance!
- Tyler
55chevr
Tyler --- What class does the bike race in ...
WOODY@DDLLC
55chevr
Tyler.
The short answer is that over 175 mph front brakes are required.
We ran 189 at the Texas Mile with the 1000 in 05... in Bonneville trim... too much weight, no front brake...  made for a nice blue back brake after it cooled enough that you couldn't feel it from a foot or so away.  Rob was only in the dirt a couple of times  :-o
I would suggest putting on the front brake for any of the mile events.
55chevr
From AirNav;
"Runway 4R/22L
Dimensions:  9000 x 150 ft. / 2743 x 46 m
HAS 200 FT PAVED AREA EACH END.
Surface:  concrete/grooved, in fair condition "
The starting line is right at the north end of runway. The mentioned 200' run off apron is staging area. Timing is the last 132' of the mile. There is .704 mile of shutdown plus the 200' runoff apron.
If you want to see an aerial view;
https://maps.google.com/maps?hl=en&q=wilmington+airpark+ohio&bav=on.2,or.r_gc.r_pw.r_qf.&bpcl=35466521&biw=1786&bih=874&wrapid=tlif135135341407510&um=1&ie=UTF-8&sa=N&tab=wl
panic
Full width drum vs. disc:
Drum has inherently stronger wheel with shorter spokes, narrower aero profile, no parasitic drag
Disc needs less contact area for the same BTU dump (higher pressure), faster cooling of fraction surfaces, only some calipers can be completely floated for no-drag in release mode
tylerm
Thanks guys. The SCTA classes are 750cc A-VG and 1350 cc A-VF. The 750 (1955 Triumph) has no front brake, drum rear. Ran 120.9 at Bonneville.. so far. The 1350 is a dual-engine 1955 Triumph, no front brake, disc rear. Ran 129 mph so far, only have 12 or so runs on it as of yet, should be able to up that a decent amount.
RacerX9623
Twin engine Tryimph.  :-o. O man I can't wait till spring. You got any photos ?
trying to go 200 KPH with a 250cc four stroke.
relaxedphit
Eric, you spelled the motorcycle brand like I rode it, but yes...pictures,pictures
RacerX9623
If I spell Triumph right can we have a video.. :-P
relaxedphit
Marvelous videos - caught a couple of your others while on youtube. What did y'all run on the salt?
RacerX9623
Thanks for the Videos. That is a beautiful piece of work. I cant wait to see it. And hear it.
Loved the sound when it was leaving the line!  :-D :-D :-D
