Posting struggle
Started by azgearhed, October 31, 2012, 05:16:18 PM
azgearhed
I can't seem to post without problems. I just tried 4 times and gave up. I was trying to attach photos. First-file size too  large. I resized-then it said you already posted this-but it wasn't posted. What am I doing wrong?
BC Racing 1979 Z-28
AA/CBGC Record 251.802 Speed Week 2012
AA/CBGALT Record 255.382 Speed Week 2013
AA/CBGC Record 226.104 El Mirage Sept 2015
AA/CBFALT Record 227.954 El Mirage June 2016
AA/CBGC Record 267.878 Speed Week 2018
AA/CBGALT Record 236.458 El Mirage Nov 2016
It's a lot of work to have fun...
I have the same problem: if the first attempt fails you're doomed
Moxnix
Re-name the re-sized file?
I'm afraid that Moxnix has the right answer - re-name the file.  It's a pain in the keester, and I have to do it now and then, too.  It's something that's part and parcel of the Forum's software and I don't know a way to get around it.
I try to pay attention, as I'm getting a photo or file ready to post, to the file's size.  If it's anywhere near the system's limit of 500k bytes I put the thing up on the Photobucket site, where size doesn't matter, and then use their link to our site/Forum here.  it's another pain -- but at least it works the first time.  As for re-naming the file (see paragraph 1) -- remember that the computer is kinda dumb - that re-naming might consist of changing or adding just one letter or digit.  That is, "AZgearhead" might become "AZgearhead1".
So you said you tried four times without luck.  Two of 'em were the photo/size/name thing -- were there more hassles?  Lemme know - via PM if there's something you want to put on the Forum as a surprise or whatever.
In the past I found that annoyance frequently. So I too would change the foto file name.
If the image had a number, just change the number. If it was a named file, w/o any numbers, add a comma.
The software can immediately spot a post with a rejected number and the only way around it is to change the name of the image.
On Landracing.com there are several foto posting rules.
Four images is the max for one post and they can not exceed 500kb. So if one image is 450kb and you try to add another
it can only be 50kb.
So plan your post. Max 4 images. Max 500kb per post.
Learn the rules and you won't whimper as often.
Landracing.com doesn't know that you rule your universe.
Landracing.com rules your posts.
Yes, re-naming the photos is necessary but you also need to change the text of your post or you will get the same message.
azgearhed
Thats what I was lookin for 8-) I had changed the photo name, but on subsequent attemps to post, it said (it?) I had already posted. Change the text to succesfully post-thanks Neil :-D
BC Racing 1979 Z-28
bobc
#7
Just a troubleshooting post, again.
Web Elf
