Engine for sale
Started by toclub, November 01, 2012, 02:08:28 PM
toclub
432" BBC. Lightweight 3.75" stroke crank, profiled and pendulum cut, Gerator oil pump, Alum sheet metal pan, Eagle H-beam rods w/L19 bolts and coated bearings, 4.280" J E 13.5 to 1 pistons w/ gas ports and zero gap rings, new Pro Comp belt drive, Latest Pro Comp Alum heads, 2.300" tit int. valves, 1.88" SS ex. valves, Jessel shaft rockers, Crane 737" roller cam, Crane roller lifters, alum sheet metal valve covers, MSD crank trigger and dist w/ wires, comes with single 4500 intake or holley pro dominator dual 4500 tunnel ram ( both set up for EFI or carbs). Complete Mcleod dual disc clutch and flywheel. Three passes sense freshened up. Ran 234 MPH on first full pass @ WOS in 4500# car.  $7000 firm + shipping. Add $500 for Ron's 2000 cfm throttle body. Add $300 for 72 lbs Seimans EFI nozzles and fuel rails.
Glen  760-241-5334
